Previous in Forum: open surface evaporation   Next in Forum: Vintage Guitars and Blacklights
16 comments
Material Properties for Expanded Polystyrene Foam
02/23/2009 9:54 AM
I am in dire need of material properties for a expanded polystyrene foam with densities of 1.12 & 2.8.
The information I need surrounds
Uniaxial test data with components of nominal stress versus nominal strain.
Simple shear stress test data with nominal shear stress versus nominal shear strain versus nominal transverse stress.
Take $5, go to WalMart, buy yourself a mirror, and look the problem right in the face.
Re: Material Properties for Expanded Polystyrene Foam
02/23/2009 2:24 PM
Density units?
02/23/2009 3:03 PM
SI g/m3, g/mm3, or kg/m3.....
02/23/2009 4:57 PM
1.12 g/m3 ≠ 1.12 kg/m3
And what is mm3? Cubic millimeters? You need to know with certainty what the units are before you can do a property search. You may also need to convert "your" units to match the property search input units.
Mike
02/24/2009 9:02 AM
Mike:
What I need is gm/cc - typical densities for packing Styrofoams.
We can convert other units if necessary.
Thank you
Good Answers: 101
02/23/2009 4:25 PM
02/23/2009 4:48 PM
I think you meant www.matweb.com
02/23/2009 4:50 PM
and a search of "polystyrene expanded" yielded 176 results
02/24/2009 9:06 AM
RVZ717 & Guest:
Thanks for the matweb tip. That was the first place I looked. Unfortunately, there is not sufficient stress strain data available to run a non-linear transient dynamic analysis to fulfill the *hyperfoam criteria. I suppose if I paid the fee, there might be some data in there sufficient enough to put in this Abaqus run.
Good Answers: 101
02/23/2009 4:50 PM
yes i did mean www.Matweb.com, my apologies.
Good Answers: 19
02/24/2009 4:26 AM
Cordek - look for eps (expanded polystyrene). They have a data sheet that is as good as many an other.
omw7
02/24/2009 9:07 AM
OMW7:
I will check their data - thanks for the tip.
Good Answers: 68
02/24/2009 7:53 AM
Hello BAM BAM,
I do not know if you want a block or sheet of a certain thickness so check these out please?
  1. Polystyrene Packagingwww.advanced-pp.co.uk/polyst Supply polystyrene packaging stock design or tailor made
  2. Expanded Polystyrene UKwww.Expanded-Polystyrene.co.uk Packaging, Display, Construction Sheet, Bead, Insulation etc.
  3. Polystyrene Insulationwww.styrotech.uk.com All Insulation,Sheet,Void Filling Blocks,Bespoke Profiles & Infil
Tip: Save time by hitting the return key instead of clicking on "search"
Search Results
  1. CR4 - Thread: Material Properties for Expanded Polystyrene Foam 23 Feb 2009 ... I am in dire need of material properties for a expanded polystyrene foam with densities of 1.12 & 2.8. The information I need surrounds ...
    cr4.globalspec.com/thread/33833/Material-Properties-for-Expanded-Polystyrene-Foam - 19 hours ago - Similar pages
  2. Polymer Testing : Deformability and tensile strength of expanded ... The behavior of expanded polystyrene (EPS) in bending [1] and under compression [2], .... 4b, −1, 0, 6.19, 0.168, 1.12, 0.142, 125.0, 5.84 ..... for all tested EPS boards is 2.8% (according to 71 statistical units, i.e. test results) ...
    linkinghub.elsevier.com/retrieve/pii/S0142941807000955 - Similar pages
    by IY Gnip - 2007 - Cited by 2 - Related articles
  3. Journal of Food Engineering : Effects of operating conditions on ... Expanded polystyrene (EPS) is used extensively in single-use packages due to its ... More than 1.12–105 ton of EPS were used for post-consumer protective ... compared to 8.9 kg/m3 for the commercial expanded polystyrene foam. .... 9 indicates that the average pore size of the extrudates ranged from 0.45 to 2.8 mm. ...
    linkinghub.elsevier.com/retrieve/pii/S0260877404004649 - Similar pages
    by WB Lui - 2005 - Cited by 1 - Related articles - All 2 versions
    More results from linkinghub.elsevier.com »
  4. A. D. Little Report: Foam Insulation Extruded polystyrene (XPS) board stock. Spray polyurethane foam (SPF) roofing which is .... calculated using the Owens Corning Global Energy Masser, Version 1.12, computer model. ... including expanded polystyrene and fiberglass type insulation. ... 2.8, 2.6 4.1. Avoided from annual energy savings, 22, 28, 1.1, 1.4 ...
    www.arap.org/adlittle-1999/9.html - 37k - Cached - Similar pages
  5. [PDF] Unknown File Format: PDF/Adobe Acrobat - View as HTML
    consisting of 13-mm thick expanded polystyrene foam laminated between 3-mm glass ..... of the differences and the standard deviation were 1.12 kg/m3 and ...
    fire.nist.gov/bfrlpubs/build97/PDF/b97069.pdf - Similar pages
    by RR Zarr - Cited by 3 - Related articles - All 4 versions
  6. Directional flexibilization of expanded thermoplastic foam sheet ... The process of claim 4 wherein the polystyrene resin foam is ...... 2.8 1.09 10.6 51.5 1.0 Go Go Go Ex 125 44.8 0.52 .... 1.12 0.9. R225 32.8 0.61 ...
    www.freepatentsonline.com/4510268.html - Similar pages
    by H Tonokawa - 1985 - Cited by 3 - Related articles - All 3 versions
Take care...................................
02/24/2009 9:08 AM
Babybear:
Thank you for the plethora of leads!!!!!!
Good Answers: 25
02/24/2009 6:33 PM
The EPS molders association can lead you to the brains in the US.Their website is www.epsmolders.org
if they don't help you, send me a personal note and I will give you a name and number>
Goodness has nothing to do with it.
Good Answers: 68
02/25/2009 2:03 PM
Hello beriberi:
GA to you for giving the address of the (probably) one organization who can supply detail or who questions can be asked of.
As far as I know the density of the 'Styrofoam' depends to a large extent on the weight and/or size of the product it has to protect? I have received a very open cell foam and an extremely dense foam. So I think the weight has to be part of the equation.
Take care anyway..........................
Good Answers: 25
02/25/2009 2:31 PM
I doubt there are curves for the densities requested. EPS just isn't that precise. It is a gas expanded plastic whose density control is something of an art and seldom is carried to 2 decimal points. Then the molding which follows is another imprecise art. Since this is a difficult material to measure and get reliable repeatable results I question if this is the material desired.
May I inquire as to the end use?
Register to Reply 16 comments
Anonymous Poster (2); babybear (2); BAM BAM (5); beriberi (2); Mikerho (2); omw7 (1); RVZ717 (2)
