Previous in Forum: Leaking Metallic Bellows   Next in Forum: Polyisocyanurate (PIR) Insulation
10 comments
Drying a Tube After Hydrotesting
02/24/2009 2:15 AM
How we can do drying of tube after hydrotest in watertube boiler
Re: Drying a Tube After Hydrotesting
02/24/2009 2:56 PM
use foam pigs and air to push water out. Then purge with dry nitrogen.
You can also pull a deep vacuum, 28.5+ in Hg would get the H2O out.
02/25/2009 5:17 PM
How about if I don't want to use pigs
02/26/2009 2:58 PM
^ blow a lot of air through the pipe
03/02/2009 9:02 AM
Hot air works better than cold air.
02/26/2009 3:25 PM
What do you think that is better if I want to dry the pipeline without pigs?
If I run only super dry air without pigs will I need to use more pressure so the pipeline can get completly dry or it does not matter?
Could you send me any link where I can read about pipeline drying?
Thanks
02/26/2009 3:48 PM
If you don't use pigs (even simple foam ones) it could take months to dry.
Just google it.
http://www.michell.co.uk/documents/en/pip/pipeline_drying.pdf
02/26/2009 4:01 PM
I tried that page but it doesn't explain me too much about time to dry. That even doesn't say that I need to use pigs.
thanks
02/26/2009 4:29 PM
time to dry is function of water left in and humidity of the drying agent. Do you material balance. If you use 100% humity air to blow through the line, the time required will be infinity. If you dry the air to bone dry, then every cubic 1 million cubic feet of air can pick up 30 pounds of water at 100% mass transfer rate.
This is enough google other sites, google "foam pigs" research research.....
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
02/26/2009 5:29 PM
Some years ago we needed to put a 500MW watertube boiler (2100 t/hr) into long term storage, after hydro and before operation. It was a coal fired boiler for power generation. The only confident means was using an arrangement of dehumidifiers connected to the water/steam circuit to attain a specified level of humidity prior to charging with nitrogen and maintaining a positive pressure. This was successful for a period of approx 6 years storage.
Good Answers: 61
02/27/2009 3:57 PM
Hmmmmmmmm?
My question from the beginning of this posting is, if we are going to put water in the tubes of a water tube boiler why do we need to dry them out? Why not just flush them out with demineralized water?
What has "Guest" not told us?
Do it once and do it right
Anonymous Poster (3); AussieBob (1); healybj8 (1); PennPiper (1); PWSlack (1); vicini (3)
