Previous in Forum: Metal Oxide Varistor (MOV) Claims   Next in Forum: Conduit Runs and Pull Boxes
Industrial Cubicles - Temperature Rise and Heat Loss
02/24/2009 9:41 PM
Dear Sir/Madam,
We will like to know the calculation procedure to estimate the temperature rise inside an industrial cubicle (for various deg of protection, e.g. IP54, IP41 & IP20 etc) based on the heat loss inside the cubicle.
With Thanks and Best Wishes,
Samaresh
Pathfinder Tags: Temperature Rise
Re: Temperature rise inside a Cubicle
02/24/2009 11:46 PM
Samaresh,
Have you given thought as to what kind of information would be necessary to give you an answer? You know - minor things like cubicle materials of construction, thickness of said materials, inside temp, outside temp range, and much, much more.
Please repost with more specific information.
Mike
South Africa - Member -
Good Answers: 12
02/25/2009 1:11 AM
Hi there,
As stated earlier - you will need to provide a lot more information. There is a compant called Sarel who has software for calculating this - although you are going to have to input the variables already mentioned as well as quite a bit more.
Regards,
Craig
Register to Reply 2 comments
