Previous in Forum: Three-Element Control and Boiler Selection   Next in Forum: Krohne Ultrasonic Flowmeter
magenetic flow meter
02/25/2009 6:05 AM
i am use in endrees and hauser flow meter promag 53 , DN 80 in highly acidic material temp of 135 deg this flow meter problem r get fluctuation of flow and totalizer
Good Answers: 54
Re: magenetic flow meter
02/25/2009 9:24 AM
There could be several reasons for a noisy flow indication.
  • There really is fluctuations in the flow - may be caused by improper installation such as a valve or bend just before the flowmeter. Maybe the flowmeter is close to a pump. Whenever possible, I try to have at least 30 diameters of straight pipe before a flowmeter, no matter what type it is.
  • You have a partial clog in the pipe
  • Your flowmeter's power supply has noise in it
  • Your flowmeter is improperly grounded
  • Your signal cable is running close to a high power cable - variable frequency drives are especially bad for analog signal cables.
  • Your pipe is vibrating
  • If you have flow control loop, your PID settings are probably too sensitive for flow. The control valve may be always over-correcting
  • Your flowmeter may be defective.
regards,
Vulcan
Reply to Forum Thread
You might be interested in: Gas Flow Meters, Flow Meters, Paddlewheel Flow Meters
