Previous in Forum: AC Drive with DC Bus?   Next in Forum: difference between AC3 & AC1 duty contactor
15 comments
Using a Fan to Charge a Battery
02/26/2009 3:50 AM
hello ...dear members i am having an idea that by using a fin(small fan) we can generate a small amount of power which is sufficient to charge a mobile battry ...its a good idea and very efficient for peoples who r going for a long drive and also its easy to produce ....but i am finding difficult to store the power....the method to produce power is u just attach a small fan besides headlight or fuel tank ....now the power is generated according to the principle of faradays law of magnetic induction...that a mechanical rotation is converted into electrical power.... so just me how to sustain the power as it is not constant in rotation
tuffelahmud
Good Answers: 101
Re: mobile battery charging
02/26/2009 4:59 AM
Are you suggesting installing a wind turbine on a car to generate electricity to charge a battery for the car? You could do it, but it's just not practical. For one thing, the drag increase will eat away at your fuel efficiency. For another thing, it's a safety hazard to bikers and pedestrians.
Here's a friendly word of advice: you're not the first person to bring this idea up. Everyone else who had soon found his/her thread become a place to post jokes, so you better brace yourself for some (actually a lot of) ribbing.
On the plus side though, some bikers and pedestrians might actually appreciate the free haircut......
02/26/2009 10:04 AM
In the 50's I worked at the local airport as a gas attendant and saw a lot of single engine two seaters with propeller driven generators. These planes were originally used without radios or lights and had no way of driving the generator with the engine.
The generators were attached to get engine prop wash or to wing struts and wired to a battery in the fuselage. Worked great for the intended purpose.
However, as mentioned, it is not free energy since the drag required the engine to work harder and burn more fuel.
Also, bicycles had generators driven by a friction on a tire to run lights as long as you were moving. A mechanical method was used to move the friction drive onto the tire.
Bud Trinkel
Re: Using a Fan to Charge a Battery
02/26/2009 10:38 AM
Similarly, spray planes use propwash to drive the spray system's pump.
At a glance, it seems like topping off a battery wouldn't be much of a load. But a battery is just a storage tank. Obviously, there's no free lunch, but there's no cheap lunch either, when it comes to watts in vs. watts out. Efficiencies take their toll.
Know your load. Then, investigate props & blade pitch & size, and efficiencies.
Good Answers: 54
02/26/2009 9:53 PM
Someone's beaten you to it. It's already been invented and marketed. Check this out:
http://electronics.howstuffworks.com/gadgets/travel/wind-turbine-chargers.htm
Read the whole article, not just the first page.
regards,
Vulcan
Good Answers: 39
02/27/2009 12:33 PM
Also check out ( google) DURACELL crank light. Amazon advertise it for $49.95 but Costco sells a pair for $13.95 and I have seen them in dollar+ stores for $5.95.
Point being there are so many ways to charge portable devices via USB port already. Hardly worh the effort to re-invent the wheel so to speak.
I do get a kick out of the advertising that these work to recharge cell phones when you go into the wilderness. Hmm wilderness - cell phone with 5 mile range?
I guess if you are a New yorker and think High Park is wilderness, the advert might appeal. Maybe the ad writer must have been thinking of a true sat phone, not a cell phone.
Elnav
Good Answers: 12
02/26/2009 10:54 PM
Hello tu5lahmed,
My son made a project 8yrs back; Powered LED with discarded PC cooling fan.
Cell phone chargers powered by small fan available in Indian market over many a mobile store.
Subramanyam
Good Answers: 38
02/26/2009 11:04 PM
Take the cigarete lighter out and put a car mobile battery charger in it, that is easier.
Put the fan on the exhaust at least then you are using fumes that will not cause more drag to the car
02/27/2009 4:57 AM
Actually inhibiting the exhaust can affect your fuel efficiency see tidbit below:
Exhausts alter fuel efficiency
Most cars have special sizes for the exhaust. When cars are reasonably old the tailpipe has to be changed. The garage people always try to fit a size that they have in the garage it self. Which might not be the exact size recommended for the car. The wrong size a bigger or smaller tailpipe size effects on the MPG of the car and the HP of the car. It may be cheaper to put another size than your recommended size for your car but in the long run it will cost you in many ways, especially on fuel consumption. Always put the recommended size of the exhaust that is indicated in your car manual because the car company knows how to optimize the performance of your car.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
02/27/2009 12:01 PM
Oh, things were simpler in the old days. Putting a larger exhaust pipe, and/or less resistant muffler on a car was an easy way to increse performance and, usually, to give it a throatier sound. I recall that replacing the tiny pipe on a Morris Minor was good for about 5 mph.
Good Answers: 37
02/27/2009 12:01 PM
"Exhausts alter fuel efficiency" True, no question.
"Most cars have special sizes for the exhaust. When cars are reasonably old the tailpipe has to be changed."
Not always true; many come with exhausts guaranteed for life of the vehicle so even if they DO need replacement, it will be a factory part).
"The garage people always try to fit a size that they have in the garage it self. Which might not be the exact size recommended for the car. The wrong size a bigger or smaller tailpipe size effects on the MPG of the car and the HP of the car. It may be cheaper to put another size than your recommended size for your car but in the long run it will cost you in many ways, especially on fuel consumption."
It is very common that a larger size (free-flowing, lower back pressure) exhaust system will actually IMPROVE power or economy, depending upon how you choose to drive. Going to dual pipes instead of a single with crossover may significantly change the results. The factory system was optimized, true enough, but not necessarily for performance. It is more likely to have been optimized for cost of manufacture and installation, unless you're driving a car intended for sporty performance - and maybe not even then. The tailpipe is only one part of the system, and rarely the most important for this issue.
Always put the recommended size of the exhaust that is indicated in your car manual because the car company knows how to optimize the performance of your car." Although I've worked as a professional mechanic in a commercial garage, serviced my own cars for more than fifty years, and read dozens of factory service and aftermarket manuals on cars & trucks built by at least 25 manufacturers from around the world and across four decades of time, I have NEVER seen a manual with an exhaust pipe size recommendation, nor do I expect ever to see one. A commercial-duty truck builder might justifiably offer such advice, but they'd also give ways to calculate the best choice for a particular use. Given the fact that bends and other restrictions, the muffler itself, catalytic converters, and installation methods can affect results, this is not surprising. Further, any modification of the engine, change in fuels available, loads imposed upon the drivetrain, speeds (especially those of the engine, as opposed to the vehicle, due to choice of gear being used) would change the optimal size. All of these factors are outside the control of the manufacturer. Oh - and if by "manual" you mean the owner's manual - no chance in hell.
But yes, your original comment, that placing the fan inside the exhaust could / would affect fuel milage, possibly as badly as one in the airstream around the vehicle, is itself correct.
" Ignorance and arrogance have more in common than their last four letters. "
03/02/2009 5:24 AM
Ron,
I do not disagree with what you have written. However, I was responding specifcially to the case where it was suggested that the exhaust be used to power a turbine. This would restrict the flow, causing a less efficient system.
Good Answers: 38
03/02/2009 7:53 PM
But ussually flow is allready restricted somewhat to create a "backpressure" the exhaust should be redesigned to keep the flow "about" the same
Good Answers: 38
03/01/2009 10:01 PM
I good inventor takes that in considerartion off course
02/27/2009 3:38 AM
Stick a voltaic cell on your window and charge your mobile from that. I keep AA batteries on my vehicle plugged in to a set of small solar cells, this gives me a spare set ready to go any time.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
02/27/2009 10:25 AM
Check out this website;
LINK
They have a little hand-held wind powered generator, as well as small, personal photovoltaic panels. The little wind generator has a built-in LiIon battery for power storage.
This would work good for your suggestion, but as others have indicated, you would get better efficiency just using a DC-DC converter plugged into the cigarette lighter socket.
The little wind generator still looks like a fun toy. For emergency power, I think I would go for solar, or maybe a hand-crank generator, before I would go for wind power.
Tom
Register to Reply 15 comments
BudT (1); d_m_rosenberg (2); DVader1000 (1); elnav (1); Epke (3); esbuck (1); garth (1); kvsubramanyam (1); Ron (1); tdesmit (1); Vulcan (1); wooliver (1)
