Previous in Forum: Pellet Stove Problems   Next in Forum: Concrete for a Stem Wall Foundation
10 comments
Corrupted Global Spec Newsletters When Using Vista
02/26/2009 10:35 AM
About 3 months ago, all of the Newsletters I subscribe to at Global Spec started coming through in plain text instead of HTML and if I click on any link, I am taken to "page not found message".
I tried every tweak I could think of to no avail and just started deleting immediately figuring it was a typical MS thing and would go away as it had before, after updates. But is hasn't yet.
Yesterday I was talking to a rep in one of our Federal Government Agencies and a form I was to download on their site caused the same error message when I put the link in the address bar, not a search engine. After 3 attempts, I was advised that IE7 does not like a lot of direct links used by the Government Agencies and only previous versions of IE7 and most of the time other browsers.
First, I have tried the other browsers and they are too cute, huggy, and warm fuzzy for me.
So, any suggestions on what to do?
Friend of CR4
Re: Corrupted Global Spec Newsletters When Using Vista
02/26/2009 10:37 AM
Hi qaqcpipeman,
I'm forwarding this on to our newsletter team. It sounds like a browser issue, but they may have heard something and know of a way to help rectify it.
- Chris
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
02/26/2009 10:43 AM
Chris,
Thanks.
The first time it happened early last year, it came back right away and was good for awhile, but started again as I stated.
It also happens sporadically with a couple of other ezines I receive, but never as bad as Global Spec.
My tech guru keeps telling me that it might be caused by MS Updates but should settle down within a day.
Personally,, I think he is fishing and isn't sure himself.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
02/26/2009 8:21 PM
I've been having the same problem. I thought it was because I switched email accounts from a web-based one to one I access through Outlook.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
02/26/2009 8:34 PM
Using Outlook since I joined GlobalSpec and cr4.
03/06/2009 10:45 AM
Still looking for help and feedback on this issue.
03/17/2009 12:13 PM
GlobalSpec IT guy, I have tried every tweak recommended, singed up anew for newsletters, etc, and when I click on any link as below, nothing happens. All other newsletters come through Vista and Outlook properly. You are in my address book also.
This is what I see when I click on any of the links:
Error: unable to determine mailing/contact information.
The most common reason for this is that your browser or email reader has garbled or removed a few characters from the link that you clicked. If the problem message is in your Junk or Bulk folder, try moving it back to your Inbox. Some email readers disable clicks in Junk mail.
To search for the correct message, please enter your subscribed email address:
If this problem persists, please send a message to support@ipost.com. Please use cut-and-paste to include the following diagnostic information in your message:
Timestamp: 1237306309
URL:globalspec.ip02.com/form/globalspec/viewhtml/9z1zg0gbi8o25jqb33sa2pdaqgd3b9ar059745s0kc0
Note that "view message" does not work from within
This is the newsletter format:
<http://globalspec.ip09.com/rd/9z1zigu0gicm0dqma465eqj12qhum25obpqijgl9i
k0>
Having trouble reading this e-mail? View it online <http://globalspec.ip09.com/rd/9z1z0u4ifg38ohtdmugd6phr21jd04oci6ne07u9n
2g> .
GlobalSpec: DirectU2 Building &
Construction<http://www.globalspec.com/pix/VerticalNewsletter/bc/branded
top.jpg>
March 17, 2009 Spec Search
<http://globalspec.ip09.com/rd/9z1zd30sbi6arthcoe9qrncvvm0fb1fuqbmar6p8u
p0> Search Smarter.
<http://globalspec.ip09.com/rd/9z1zgnkcschb4c5fpugnnvt433hefhs0n79v63moq
to>
Search by specification
to find Building & Construction
products and services.
Industry Trends & Events . . .
<http://www.globalspec.com/pix/VerticalNewsletter/Spacer.gif> Forward
to a Friend
<http://globalspec.ip09.com/rd/9z1z0hbd7rh1kleger23f26sb7baqrmdekj29lidp
5g> Forward to a Friend
<http://globalspec.ip09.com/rd/9z1zm0d349df78f30s5frnfave5gqiuvuejofvjt7
k8>
Demolition Dis's the Dynamite
<http://globalspec.ip09.com/rd/9z1zgk019p54sbs7pqucmttepuksvr8923d71l47n
v8> Imagine standing in the shadow of a skyscraper that's about to blow
— once the demolition foreman pushes the trigger. Sound like something from a nightmare?
Not with demolition technology developed by Japan's Kajima Construction.
Instead, the ground floor is "disassembled," hydraulic jacks lower the building, and the process repeats. Evacuating entire city blocks to protect people from flying concrete, glass, and steel is no longer necessary. Dust and noise are greatly reduced; there is virtually zero disruption to surrounding structures
<http://globalspec.ip09.com/rd/9z1zkehm9supn0n0ghmuoffq19vhi292ko4537p63
tg> ; and more demolition material is saved and recycled.
New e-Newsletter Titles
Coming Soon...
• Construction Tools & Equipment
• Food & Beverage Technology
• Healthcare Manufacturing
• Oil & Gas Technology
Subscribe Today
<http://globalspec.ip09.com/rd/9z1zra373av9hiq5um412h60aog2rap4b3muccdkj
a0> !
Spotlight On . . .
Back to Top
DGS100 Digital Time Switch Special Feature
NSI Industries LLC
<http://globalspec.ip09.com/rd/9z1zta6auq3nmc8vp0mbgismlt3cbqcqd8rkc7001
4o> Think you need to erase or modify your seven-day program for a
special event or season? You don't! With the DGS100 <http://globalspec.ip09.com/rd/9z1zila04ov91udrkavt2edfc2nlm87d7c2qqd13s
so> , your standard program remains intact with use of the Special Day
button. Allowing bypass, execution of alternate program, or disabling a current program, this timer is ideal for year round AND seasonal applications. Learn more
<http://globalspec.ip09.com/rd/9z1zu4p1q9fg5nddhu76umc8d40tac9d5ui0d5h08
lg> .
Save Energy Costs and Reduce Carbon Emissions Right Away Harmonics Limited
Save Energy Costs and Reduce Carbon Emissions Right Away <http://globalspec.ip09.com/rd/9z1zu02ceqm77j2a912lmukpumtgqo607kv7sofha
jg> Learn how to lower energy usage and obtain full capacity in both
existing buildings and new installations with our patented Harmonics Suppression Technology (HSS). Significant annual savings, attractive ROI. Visit our Web site here <http://globalspec.ip09.com/rd/9z1z0b3ogdrcdvibp3ij2n3sbuf84n7avgleao63j
ao> .
Harmonics Limited: The Green Way to Sustainable $avings
<http://globalspec.ip09.com/rd/9z1z5dsk6pi4hke2g0n2q7bnaq696rfs1mc1v8m96
ro> .
Energy-efficient Industrial Heating
Detroit Radiant Products Company
<http://globalspec.ip09.com/rd/9z1z6bqfv26taerb0921jsdplq5mkk268jl2j63nv
ng> Gas-fired infrared heaters are a great contributor to energy
savings
<http://globalspec.ip09.com/rd/9z1zujcvqm9gk1mmo0mfsutpispam2kjg6tvglg2p
0o> and have documented fuel savings of 23 to 50% when comapred to
forced air heating. Infrared heaters require very little maintenance and operate quietly and clean. Request your no-obligation analysis today <http://globalspec.ip09.com/rd/9z1zoos6kttk03f9loqgbrd79p5pipg1a8k7ml5ut
20> !
PowerMount — Prefabricated Wiring Assemblies Leviton Wiring Devices
PowerMount — Prefabricated Wiring Assemblies <http://globalspec.ip09.com/rd/9z1zvuek5lscl5lv7kpnil6h78a85j72817b1ck6r
98> Leviton's PowerMount
<http://globalspec.ip09.com/rd/9z1zfi76i43pg6kinrvcv5jj80pvlpfke7sdckg1h
c8> ™ system features pre-assembled electrical boxes containing mud
rings, integrated stud-mounting brackets, pre-installed ground wire, and Lev-Lok® wiring modules. Used in conjunction with Leviton's comprehensive line of modular receptacles, contractors will experience significant labor savings: jobs can be completed ahead of schedule and under-budget. Learn more
<http://globalspec.ip09.com/rd/9z1zoke3djh0ctpjcjgtivsnr1hrbe3dr3ircgrt2
mo> .
Construction Products . . .
Back to Top
Learn More
<http://globalspec.ip09.com/rd/9z1zlbd3clj0v2ru7t31ss9ln7772lhcnmlovsb9i
r0>
Preserving Farm-to-Market Roadways
<http://globalspec.ip09.com/rd/9z1z43858g6cg1a08ig7takmf3ki6hl6hjilhk2fs
2g> Times might be tough, but in North Carolina "farmers must still get
to market." For decades, "full depth reclamation with a cement additive"
was the fix for potholes and road surface cracks. Now, the North Carolina Department of Transportation is exploring a less expensive option for pavement preservation <http://globalspec.ip09.com/rd/9z1zm3m8h8u0m8p2lakv0fc93lm40fp6o2415alph
08> .
They Turn Paper into Stone
<http://globalspec.ip09.com/rd/9z1z8qfvqq20s7v99oe74igba72p77aq1l3tvquug
ug> When you toss that old phone-book into the recycle bin, it's quite
possible the shredded stuff will turn up again as countertops or floor tiles <http://globalspec.ip09.com/rd/9z1z3iibl2m89najlm7h1rrtf1ngrrb1jn8ca4grb
5g> in your refurbished office — thanks to engineers who have
discovered the secret of turning soft paper into hard, stone-like construction products.
Tools & Equipment . . .
Back to Top
Learn More
<http://globalspec.ip09.com/rd/9z1zpjd0h2s7978kg20vmfvm6rdimsvekf8bfnjt3
q0>
I've Been Working on the Slide Rail
<http://globalspec.ip09.com/rd/9z1z7d5cuu6p3niqdmlpc6psniens5a1jc1pbhsq1
48> How are construction engineers solving the problem of excavating
narrow manholes on steep inclines while, at the same time, preventing catastrophic cave-ins? By seeking out non-traditional shoring methods such as the slide rail system. This "dig and push" system of vertical steel posts and steel panel components is designed to shore up excavated soil
<http://globalspec.ip09.com/rd/9z1zhcsiiqovu1md95er0nigmbdgbhc867i935j85
b8> in the tightest of conditions.
The Curious Case of Cat D11N...
<http://globalspec.ip09.com/rd/9z1zr1c9ci2782v932iueks0odvagi5b8ktl10138
8o> ...and other cool earth moving machines! If some hotshot Hollywood
director were to make a movie
<http://globalspec.ip09.com/rd/9z1zmcdnjcsdgvd2vpfq8847aqj7tr1htl1216skk
q8> about bulldozers
<http://globalspec.ip09.com/rd/9z1ziotibdlh0jk6j82it96ir74quoodmjvk6t51e
ng> , he'd most definitely give this 100 ton, 770 hp earth crawler the
starring role. This mega-machine, able to demolish a brick warehouse in a single swipe or move tons of shale in seconds flat, makes an Abrams Tank look like a toy. Now, if only you could get its autograph.
Accent On . . .
Back to Top
KIMAX® Laboratory Glass Drainline
SCHOTT North America, Inc. — Tubing
KIMAX? Laboratory Glass Drainline
<http://globalspec.ip09.com/rd/9z1zg013r08i3s21n2qtvevrmbsiu1l9ko36judnm
oo> KIMAX®
<http://globalspec.ip09.com/rd/9z1znnkffogh15haqjh8bp2nn33diopc5kn50e7ro
t8> borosilicate glass drainline systems are designed for the transport
and neutralization of acid waste. KIMAX® is a sustainable and reliable solution for acid waste piping
<http://globalspec.ip09.com/rd/9z1zo4fb1krd8tb4p332api81bh1snff5ibqpgit6
qo> offering the key features of adaptability, modularity, maximum
corrosion resistance, full temperature capability, low thermal expansion, and the lowest life-cycle cost in the industry.
All Marks Are Not the Same
Underwriters Laboratories Regulatory Division
<http://globalspec.ip09.com/rd/9z1z3c5nm9960tit4jng581mgp3l6oihn8rs51hg4
h8> The UL Mark stands alone.
When it comes to safety, the UL Mark — the one and only, the original — isn't given; it's earned. Be sure to verify UL Product Certification.
It's easy if you know the manufacturer's name and model number. You can check here <http://globalspec.ip09.com/rd/9z1zcr05jl913s204udhq0q687h9hijr8ju4r1k2n
m0> .
Pre-assembled Steel Framed Buildings
Trachte, Inc.
<http://globalspec.ip09.com/rd/9z1z1nhnbi1p84nig0sot8a9l2v7flsv9ugl1rt81
ug> Trachte
<http://globalspec.ip09.com/rd/9z1z68t12ntuq42urmh0ol9ghiffvkrdlcaqb7kl0
j0> provides modular, prefabricated buildings
<http://globalspec.ip09.com/rd/9z1zf3ujt4eqbb5rierbvqsn5019mgk2i0ouqm5qv
k8> , shelters, and large-format enclosures in transportable sizes from
4 ft to 30 ft wide. Because Trachte buildings are pre-assembled, they are equipment-ready immediately after delivery and placement.
Pre-assembly saves time and money by streamlining projects and facilitating the acquisition of multiple small complex buildings.
Videoscope with Integrated Monitor, Image Capture Medit
Videoscope with Integrated Monitor, Image Capture <http://globalspec.ip09.com/rd/9z1z4cleknokmoebth411clkp2k0rg285ano1ovkc
p8> Do you seek for a portable videoscope with an excellent image of
the inspected area? Then Medit Portable Videoscope with Integrated Monitor <http://globalspec.ip09.com/rd/9z1zkr4gdamnnn88ohr85vr2o7itedi6kc3sts56j
u0> is the best choice for you! With diameter of only 5.5 mm and
interchangeable probes, Portable Videoscope <http://globalspec.ip09.com/rd/9z1ze3s6mejgdhgjtkgs10se7pctkdn55gocs8gtm
6o> can perform all types of remote visual inspections.
Building Materials & Hardware . . .
Back to Top
Learn More
<http://globalspec.ip09.com/rd/9z1zgb9l9gd9laa3v7et050f7b74rruc1dhmr19gr
vg>
Going Up?
Going Up?
<http://globalspec.ip09.com/rd/9z1z920361ovuhe6knanvm4anmd73s95lq89m6srh
9g> The good old days of elevator operating bellman are long gone. But
in the near future, elevator controls
<http://globalspec.ip09.com/rd/9z1z5un2rfbtqmqst6he4lgkmb5amoufl6a924v01
co> may be eliminated as well — replaced by lobby-located,
multi-function, destination-based, dispatching systems. This report from FacilitiesNet explains...
You Say You Want a Revolution
<http://globalspec.ip09.com/rd/9z1z83mc1qrudllptvhoejkjnt3ndeo3ve9gu1dbn
2g> Looking to create an energy-efficient, air-locking, revolving door
<http://globalspec.ip09.com/rd/9z1z90sb4evfkvpdcb0mhgvli42ue9td2khptns93
mo> for the front entry of your commercial high-rise? This
newly-engineered system features a first-ever, state-of-the-art glass ceiling. How does it work without shattering? Instead of powering the door's central shaft from above, as in traditional revolving doors, this one is powered from below.
Green Design . . .
Back to Top
Learn More
<http://globalspec.ip09.com/rd/9z1z4cbubsesif1osjoguhr64c7fallipg6dqv4bl
58>
Reading, Writing, and Renewable Energy
<http://globalspec.ip09.com/rd/9z1zbd36baktlkt6vv7qfamsssgkl593os02ijk0u
3o> How has one California college preparatory school managed to
generate its own electricity without laying out a huge capital investment? By installing a unique system of photovoltaic solar panels <http://globalspec.ip09.com/rd/9z1z3atrlvaln0k28cscvp5sb582k914fjdb4ak0g
88> , engineers were able to provide the school with enough carbon-free,
renewable energy to supply up to half the school's everyday needs. The positive message sent to the community, says one school official, "helps us in our recruiting efforts."
Sustainable Skyscraper Software
<http://globalspec.ip09.com/rd/9z1zcdgrlc9tp4mkpmdp1nbv5r7rib2635gfssikl
io> From Dubai's "outrageous" Dynamic Tower, to the "fur coat" design
of Russia's proposed Gazprom Headquarters, computational fluid dynamic software <http://globalspec.ip09.com/rd/9z1zsbvig05n8mr1v8voahkr6p419q4n0tl421f3q
n0> and environmental data gathering techniques are guiding the green
commercial building movement. This growing trend is intended to reduce each structure's "overall impact on this planet," no matter how strange the result may look.
Focus On . . .
Back to Top
Demag Travel Wheel System
Demag Cranes & Components
<http://globalspec.ip09.com/rd/9z1zaj2it4j6558454q0fkp42mb0mdk38lr68t2ua
c0> The Demag Travel Wheel System
<http://globalspec.ip09.com/rd/9z1zkf3vcftd9lbbvgps6faba0odmptqq3ldmlm9v
do> is designed to move loads over a wide range of speeds and
applications. With wheel loads up to 132,000 lbs, the wheel system offers simple assembly and alignment. The wheels can be easily driven by means of a Demag gear motor <http://globalspec.ip09.com/rd/9z1zgu19hv3gjgj5v4t99ghc1end51r9vjeus7bbh
a0> connected directly to the wheel.
It's Easy Being Green with Nichiha
Nichiha USA, Inc.
<http://globalspec.ip09.com/rd/9z1za2hgjo17rnnqp0d5o3i3p8925r3osru8hf2h5
oo> Sourcing green building products that contribute to LEEDs
<http://globalspec.ip09.com/rd/9z1z3iso24iqtgcrua971o09n1u09a64123sp29o8
s8> and have low installed cost without compromising on appearance has
been solved with Nichiha fiber cement panels. Uncompromising quality and performance combined with the design flexibility of over 30 brick, stone, block, and shake textures <http://globalspec.ip09.com/rd/9z1z08cv2viv6dvuo6smqlqgq75gpues0othmvoub
l8> and you embody integrated value.
Your Competitive Advantage for Hydraulic Replacement Cylinders and Parts Aggressive Hydraulics Inc.
Your Competitive Advantage for Hydraulic Replacement Cylinders and Parts <http://globalspec.ip09.com/rd/9z1z0h7qhavq61fjbveaa8r5c9js2bkkr7ul6md7p
c0> If frequent cylinder failures and long lead times from your
suppliers are costing you thousands of dollars in lost production, let Aggressive Hydraulics <http://globalspec.ip09.com/rd/9z1z158ngu2oukpg4u0tmksbnf8m8cf3lelrmoc5a
0o> re-engineer and manufacture replacement cylinders for your
application
<http://globalspec.ip09.com/rd/9z1zkk9ufoab8is6m5jp872fan06f3bjasn7f5i4j
68> . Our replacement cylinders and parts have been solving problems for
our customers for years. Call 866-406-4100 today.
Epilog Laser and Instructables.com Launch "Green" Contest Epilog Laser Corp.
Epilog Laser and Instructables.com Launch 'Green' Contest
<http://globalspec.ip09.com/rd/9z1zsbpb8be3n5l0b33gkeh46cfetes6fi2g6hfk1
co> Want to win your own laser engraving/cutting system? Enter your DIY
project in the Epilog Challenge
<http://globalspec.ip09.com/rd/9z1z45q543clu27m8rb6auujl8bi5mgu9ha4hr166
70> — top prize is a Zing Laser from Epilog! Discover why Epilog
systems are fast becoming popular tools for builders, designers, artists, and more. Entries accepted through April 19 — learn more and enter the challenge <http://globalspec.ip09.com/rd/9z1zllbc5t7flod9rmjq2a0hh2pf6tnj66rl0gjqb
88> !
Careers & Commentary . . .
Engineering Jobs
<http://globalspec.ip09.com/rd/9z1z6pksf4nrhnalke4smhi4nr1skv8slelhhs9nd
50> Go
Here<http://ad.doubleclick.net/ad/N1841.GlobalSpec/B2641038.4;sz=1x1;ord
=[timestamp]?>
Back to Top
Civil E's Go to Hollywood
<http://globalspec.ip09.com/rd/9z1zqulrkll5m5qgpmpddltfvqc4jel3p1aggbttm
s0> Hollywood might be the place of fantasy and make believe, but
there's nothing fictional about concerns facing the world's civil engineers. When the Los Angeles Sheraton Universal Studios hosts the
2009 Civil Engineer's Summit and Expo
<http://globalspec.ip09.com/rd/9z1zijdi360ki9to0to9pjs4562b4t0ugv0ps8ak2
no> , April 21-22, these concerns will be addressed. The annual summit
gives engineers a chance to network and share industry insider knowledge; if they are lucky, they may even catch a thrill on the Jurassic Park theme ride.
Diversions . . .
Sea Turtle Super Highway
<http://globalspec.ip09.com/rd/9z1zsd56vi0osk37njhlc8s8t423qul8nnaipr794
60> If you happen to be driving at night along the Florida Coastal
Highway, you might find yourself braking for a family of migrating sea turtles. You might also be surprised to find that the pole-mounted highway lights one normally associates with highway driving have been eliminated in favor of battery- or solar-powered, turtle-friendly LED safe-lights <http://globalspec.ip09.com/rd/9z1zha05i3siv8bhqktljo179k2776hfa1fgoc9tb
k0> .
Share Your Thoughts . . .
About This Month's Topic
<http://globalspec.ip09.com/rd/9z1zirttlakdmippc7fhp4u1rq44564v1m9jcu7qr
rg> Cutting Edge...or Just Plain Crazy?
With the architectural mantra being "the more exotic the better," the sky's the limit on the future of airport design. Or is it?
Join the discussion...
<http://globalspec.ip09.com/rd/9z1zu8tgi6pog437kgbv71nfci2p2fq24curdfi0m
4o>
Stay Informed . . .
Search GlobalSpec: Search!
Newsletter
Subscriptions<http://www.globalspec.com/pix/homepage/icons/newsletter.gi
f>
Newsletter Subscriptions
<http://globalspec.ip09.com/rd/9z1za9f9hjbu7k9tkqpsouh46jjnhkut6od4eokhi
00>
Your source for technology news and industry information
Product Alerts<http://www.globalspec.com/pix/homepage/icons/alerts.gif>
Product Alerts
<http://globalspec.ip09.com/rd/9z1zi4g32578ne9fleoo5kvqfgs2k7evfcgnucv65
uo>
Receive e-mail updates on new products and suppliers
The Brain Strainer
<http://globalspec.ip09.com/rd/9z1zou6esdi82najkquhcrf2h2ltkt957r4s3s7m0
lo>
Flex your physics muscles
<http://globalspec.ip09.com/rd/9z1zqlm26eo2nk6i3s8q9m3bc6m67s8r4dc4m7ulj
qo>
Take the Challenge
<http://globalspec.ip09.com/rd/9z1zd96e9gfumjulfpqlm7asdprnh6bcfuj0l2gqt
4g>
Directory of Companies
<http://globalspec.ip09.com/rd/9z1z407fe8tbi6vfct5gbo1sr5684opi1angtn7po
30> Technical Articles
<http://globalspec.ip09.com/rd/9z1z37tq180ccb3q9038rp1k2h18jr3a2jm98cllp
2o>
Engineering News
<http://globalspec.ip09.com/rd/9z1zam8c5tduf1up3g1kh1cu35l4uvdt7guhbfl94
ko>
Engineering Toolbar
<http://globalspec.ip09.com/rd/9z1zsovqksakj8a8frqa9nbh79fj56hphpm2gtq4u
pg>
Feedback <mailto:newslettercomments@globalspec.com?subject=Re: Building and Construction> | Media Kit
<http://globalspec.ip09.com/rd/9z1z1bhakl6e4vlaslo63g7k6baniqniob3okp432
ho> | Forward to a Friend
<http://globalspec.ip09.com/rd/9z1z8f56fq0rpnmsugqimu5vuvi3oviekg5rnkmdt
s0>
March 17, 2009 - Volume 4 Issue 3
© 2009 GlobalSpec, Inc. All rights reserved. GlobalSpec, the GlobalSpec logo, SpecSearch, The Engineering Web, and The Engineering Search Engine are registered trademarks and DirectU2 is a service mark of GlobalSpec, Inc., 350 Jordan Road, Troy, NY 12180 - 800.261.2052. All other products, company names, or other marks appearing in this e-newsletter
are the trademarks and property of their respective owners.
To ensure prompt delivery, add do-not-reply@globalspec.com to your safe senders list.
Please do not reply to this e-mail, as we are unable to respond from this address. If you would like to contact us, please send an email to:
Construction>
To unsubscribe from this e-newsletter, click here
<http://globalspec.ip09.com/rd/9z1z4bcm3vd6dujba76u11bji7f7a4tr5vqtn62o6
do> .
To unsubscribe from all GlobalSpec email communications, click here <http://globalspec.ip09.com/rd/9z1zpmu3qpib5pqlnrtspgf5p42sp606u5rno4liu
i0> .
To edit your user profile, visit Your Profile <http://globalspec.ip09.com/rd/9z1z1nec524j4c7d2vs9ap0l9a8f5jjlqpsghh65c
l8> .
If a friend forwarded this e-newsletter and you'd like to receive it in the future, subscribe directly
<http://globalspec.ip09.com/rd/9z1zkq1e4fme4u5lhh6vt3627rhhagt9gmt6l3bp5
5o> .
Friend of CR4
03/17/2009 1:53 PM
Hi qaqcpipeman,
This is a response from our tech folks:
This problem is usually the result of a conflict between your anti-virus program and your email program - the combo we've seen the most is with AVG 8.0 and Outlook.
The reason for it is that AVG adds a small bit to the end of an email to certify it as "clean", but then Outlook doesn't recognize it as HTML anymore and displays it as text... which then breaks the links.
To fix this, go into AVG's advanced settings and under the options for email scanning, uncheck the box for certification of incoming mail (this doesn't stop it from scanning your emails, just stops it from adding the certification).
This change will only affect future incoming email, not ones you've already received.
Hope this helps
03/17/2009 2:09 PM
Did this, and Thanks Chris.
Is it possible to resend todays GS Newsletters for a test?
03/18/2009 10:50 AM
Thank You Chris,
The fix worked, and I never thought about that new little annoying addon from AVG causing the problem.
In addition, it has removed the Web Site scan on searches also, which got to be a pain at times.
Kudos to you and your IT Crew.
Good Answers: 22
03/17/2009 9:58 PM
Thanks from me also. However, I haven't received any newsletters yet today. But then, they havent' shown up until late evening at times, so I'm not worried.
Register to Reply 10 comments
3Doug (2); Chris Leonard (2); qaqcpipeman (6)
