Previous in Forum: Selecting an Uninterrupted Motive Power Supply (UMPS)   Next in Forum: Parameters for Trafo Electrical Insulation
MATLAB Simulation
03/03/2009 1:34 PM
Hi..
I want to check the efficiency of a variable frequency drive compared to a normal 3 phase induction motor? how can i do this using matlab simulink? also the energy consumption is less using a VFD. How can i show this using matlab simulink?
How do u model a pump using matlab simulink??..I want to install a VFD in a Sewage treatment plant. How can i do this modelling by using matlab simulink?
Re: MATLAB Simulation
03/03/2009 9:33 PM
neednt to do this job,
just install in practice and adjust on the site.
simulink can do nothing with it.
03/04/2009 6:22 AM
Hi Roger!
Since I don't use Simulink (I got spoiled working in LabVIEW), this is the only way I can help:
1. look on matlab's website or on matlab users forums
2. try and find block diagrams or state-machine models of your motors and implement those in simulink
3. look through the simulink's library of examples
Good luck!
Patricia_a
03/04/2009 6:40 AM
If all you really need is a straight 3 phase driven motor, there is no need to compare as the extra electronics for variable speed will reduce overall efficiency for a single speed.
If you need variable speed, then you also do not need to compare, as the straight motor cannot (at least not easily) be made variable speed without using electronics!!
Its as simple as that!!
No need for MATLAB or any other simulation!!!! Total waste of time in this particular case.....
03/04/2009 8:01 AM
" as the straight motor cannot (at least not easily) be made variable speed without using electronics"
This is not true fluid couplings are another route to go for varing speed
check this website
www.suttonsofholly.com
03/05/2009 11:32 PM
you may refer to liquid or gas drived motor, but its not belong to electric facility. so Andy may still right.
if you speak to old equipment somthing look like different speed motor with liquid as coupler agent, I really havnt seen this motor. I cannt access to the web as well.
is it still in using?
Andy Germany (1); Anonymous Poster (1); cnpower (2); Patricia_a (1)
You might be interested in: Sewage Pumps, Grinder Pumps, Drains and Drain Systems
