Previous in Forum: COMPUTER COMMANDS   Next in Forum: Support for Small Business
Radiant Heat is Better
03/03/2009 5:14 PM
Tell me I ahve radiant heat in my home and the heated floors are great but how does the rest of home heat up am doing something wrong or what? help me out here I was told this was the best heat to have but my home is very chilly, I bought some room heaters this year and I don't want to go another winter like this,
any suggestions?
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
Re: radiant heat is it better
03/03/2009 7:04 PM
Find the air leaks and plug them up. You would be amazed how most houses leak.
Kevin "Dances with Trees" Willey
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
03/03/2009 10:22 PM
I have to agree with Kevin here. The heat must be going away somehow.
How well insulated is your house? You might do well to have an insulation contractor inspect it for you.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
03/04/2009 2:50 PM
you both are correct I had a contractor come to my home and it needs to be insulated better than what it is and that should take care of the coolness.
thanks a bunch, snickers2
Register to Reply 3 comments
Dances with Trees (1); Shadetree (1); snickers2 (1)
