Previous in Forum: Product Reviews? Megger MMC850 Multi-Core Clamp Meter   Next in Forum: BUSBAR
Voltage drop calculations
03/04/2009 1:46 AM
Dear all
I want to know the voltage drop calculation for the below values.
Current (I) in the circuit is 1000A
Voltage is 415V
Length is 800m
What is the cable size for the above circuit.
Please send me the calculation part for the above values
Thank you,
Re: Voltage drop calculations
03/04/2009 2:30 AM
This sounds like a homework question.
Could you please provide more information on why you are asking such a question. Are you a student or is this a general interest enquiry?
03/04/2009 6:32 AM
Hi jack,
I am a trainee electrical design engineer.
I am involving one project.In this project we have to give the cable size for the circuit which is from Main Distribution Panel (MDP) to Floor Distribution Panel (FDB) which has circuit breaker rating of 1000A,ACB.The distance from MDP to FDP is 800 Mtrs.For that we have to consider voltage drop also.
As far as i know, 3 Runs X 3.5C 400 sq.mm AYFY cable should be proper size.is it correct?
I wanna know the voltage drop calculations for this.
Please share your knowledge with me.
Thank you
03/04/2009 2:49 AM
well, I can solute it.
One dollar one answer.
Good Answers: 53
03/04/2009 3:39 AM
Iwould say 1$/Amps,
03/04/2009 5:43 AM
British Standard 7671 again?
03/04/2009 11:45 PM
Thank you ton for your repsonce.
South Africa - Member -
Good Answers: 12
03/05/2009 12:54 AM
Hi there,
This will vary according to country as well as cable specs. As stated in earlier posts goto aberdare cables - dowload cable booklet. Use calculations.
Regards,
Craig
Register to Reply 7 comments
cnpower (1); craigza (1); jack of all trades (1); PWSlack (1); rakesh_semwal (1); vanteru.madhu (2)
