Previous in Forum: Limited Articulation of the Knee Joint   Next in Forum: service lines that give life to city
8 comments
turbine safety valve
03/06/2009 3:20 PM
safety valve when preset for flow rate any increast in flow will close it and stay closed till reopened.is there one ? all the water mains are bracking they can not be closed without someone closeing them, same for gas lines.these lines run under play grown, schools, neborhoods,hwys and as there is nothing to stop these but man for are is there something else that does it instently with out man ? (yes)
Re: turbine safety valve
03/06/2009 6:42 PM
Given that it is possible to provide the type of control you want using any of several types of flow meters, a simple controller and a shut off valve. How is your leak shutdown system going to know the difference between a huge big leak and from one to several fire trucks drawing water from the main at the same time? I don't believe that water is valuable enough or dangerous enough to justify the expense involved even acknowledging the problems associated with dihydrogen monoxide toxicity and contamination.
There may be some justification where flammable or seriously toxic materials are involved. Indeed, some pipe lines do have automatic isolation systems on them. It is not usual for residential or even commercial branch lines to have such equipment.
The initial expense of the equipment, the installation and follow on maintenance costs will make most such projects economically unattractive.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
03/07/2009 9:40 AM
you need to send your coments to the city were they lose money, and lives every yr. the valve like the computer is only as smart as the one whom makes,an set the standered. sorry about my spelling i did not finish school spot
Good Answers: 123
03/06/2009 10:56 PM
I have seen these systems on air systems. The design would allow a limited flow rate. If that flow rate was exceeded, the flow would be shut off. As if a hose were to burst, the air flow would be shot. It is also used on hydraulic systems on vehicles when a failure would be life threatening. (Think of a aerial bucket truck with a person in it.)
The problem with these devices is that they must be carefully matched to the device using the stored energy. They can not tell if your pipe has burst, or you and your wife are both taking showers at the same time. Nor can it tell if a pipe buried under a road has burst, or your block is all watering their grass at the same time. They only work if on individual items.
Bob
03/07/2009 9:59 AM
yes you are right so if all that was needed to stop flow there are laods of valves! now we must think of control flow at all levels of use. at your house when no ones home the gas line under your schools, the house next door when the boom happenes every one nows what to do this valve does not wait for an answer if the flow in the line it closes there by giveing you time to do what we do bess fix it. ps once closed it will not open till you open it. spot
03/06/2009 11:27 PM
Neither of Spots posts make any sense to me. I realize that I only speak English, but, the language fails me when trying to understand such things as:
"someone closeing them, same for gas lines.these lines run under play grown, schools, neborhoods,hwys and as there is nothing to stop these but man for are is there something else that does it instently with out man"
Really, seriously, as hard as I try I cannot formulate an answer to a question that DEFIES LOGIC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03/07/2009 10:06 AM
sorry i did not finesh school but if you know valves then ask a ? i will try answer. spot
Good Answers: 101
03/08/2009 12:13 AM
Hey, give him a break will you? Here's a little article on his background; it'll help you to understand his problems a little better.
http://en.wikipedia.org/wiki/Spot_the_Frog
03/08/2009 11:08 AM
if only you had an I Q we could spell better words an not count on others to write them for uses. but thanks for your hard worke to keep up with the class. spot ps you are the dark side but i have the light on my side !!!!!
Register to Reply 8 comments
bob c (1); DVader1000 (1); lyn (1); spot (4); Turbotroll3 (1)
