Previous in Forum: Short Circuit Test : Power Transformer   Next in Forum: Electrical Protection
Air Circuit Breaker
03/08/2009 5:01 AM
How air is used in extiguishing the arc in an air circuit breaker of 400v.
Good Answers: 18
Re: Air Circuit Breaker
03/09/2009 7:52 AM
Any circuit breaker may have inductive loads on it which tend to draw an arc when opened. Sustained arcs cause vaporization of contact metal, so it's very desirable to extinguish the arc as quickly as possible. The distance the contacts must open increases with voltage. At 400 Volts, it's not much, but nonetheless not necessarily easy to extinguish.
Electric arcs are more or less a conductive gaseous plasma and can be 'blown out' like a match with high pressure air.
03/10/2009 11:24 PM
Thans Bill for ur valuable information. But I want to know what is the procedure to extinguish the arc using air in ACB?
07/24/2024 10:26 AM
See #1⇑.
Register to Reply 3 comments
Bill (1); PWSlack (1); sapan (1)
