Previous in Forum: is there any one know the railway track maintenance machinery market?   Next in Forum: Creating A Plastic Housing Container
Symbol for Exposed Aluminum Surface?
03/12/2009 2:57 PM
Hello,
I currently make the extrusion drawings for my company and submit them to vendors once they have been approved. Currently I am putting the text "exposed surface" on the drawing and placing leaders to designate any surface that will be exposed to the eye. We like to have these shapes free of die marks and blemishes because some of these will be clear coated. I would like to know if there is an industry standard symbol for this practice and if so can someone provide me with an image of it?
Thanks
Pathfinder Tags: aluminum exposed surface symbol
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Symbol for Exposed Aluminum Surface?
03/12/2009 7:16 PM
I believe you are referring to finish marks, such as these:
That illustration came from here:
http://www.tpub.com/content/draftsman/14276/css/14276_247.htm.
This link seems to have fairly complete information:
http://books.google.com/books?id=igQZ1L94vmgC&pg=PA401&lpg=PA401&dq=finish+marks+drafting&source=bl&ots=0EaTdLRQvv&sig=IAjuc7NLLekiDwnyahx32IlKIqU&hl=en&ei=nJW5SaGjA4nOtQO2y8gt&sa=X&oi=book_result&resnum=5&ct=result#PPA401,M1>
This link probably is closer to what you are looking for:
http://books.google.com/books?id=EWE-RK3F6mcC&pg=PA171&lpg=PA171&dq=finish+marks+drafting&source=bl&ots=LLzq3BbjvW&sig=DC1aL4tqM2GVlrOf4EuQnd1_VJU&hl=en&ei=nJW5SaGjA4nOtQO2y8gt&sa=X&oi=book_result&resnum=8&ct=result#PPA171,M1.
You might need to look up the ANSI standards for finish marks to find the specific information you need.
You could also add a general note stating that all exposed aluminum surfaces must be free of all tool marks and blemishes, and ready for clear coating. General notes are usually listed next to or above the title block, or close to the front view of the drawing.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 150
03/13/2009 10:01 AM
To further 3Doug's correct response, there are symbol modifiers to control not only the average RMS roughness, but the lay of any marks, the maximum and minimum deviation from the average, and what machining and production processes are allowed. Further, use of ANSIY14.5M GD&T symbology would allow you to use the profile of a surface to control the maximum deviation from true form over a given length. GD&T can be your very good friend in such situations.
I've had to deal with these issues when designing metal to metal high pressure seal surfaces.
Who is John Galt?
03/13/2009 10:05 AM
Thanks everyone for the help. Do you have a link to the ANSIY14.5M GD&T symbology information that you could provide me?
Thanks,
Good Answers: 150
03/13/2009 10:38 AM
Not a direct link, but my 24th edition of Machinery's Handbook shows and explains the modifying symbology on pages 667 through 679, those page numbers will vary depending on which edition and version of machinery's handbook you might have handy.
Additionally you can buy ANSI/ASME Y14.5M IHS.
I can also suggest that you might find a book titled Geo-Metrics III by Lowell W. Foster useful in understanding how to apply and use GD&T symbology. Mr. Foster was one of the authors of the ASME standard.
Another excellent resource that is available from IHS is their Drawing Requirements Manual.
Who is John Galt?
03/12/2009 7:21 PM
If you have a good relationship with your vendors, just ask them. If there is a symbol, they probably will send it to you so they don't have to interpret what "exposed surface" means on your drawings.
Good Luck
3Doug (1); lyn (1); Rorschach (2); tclark (1)
