Previous in Forum: Extracting Data from .CFS Files   Next in Forum: Kodak Z1485 Webcam
United Kingdom - Member - British
Video card
03/14/2009 10:34 AM
Hi
I have a ATI FireGL V3300, which has a VGA, DVI and S-video port. I use the VGA for my defult monitor, but was wondering, if I was to put another monitor onto it, is it either the DVI or the S-video?
Thanks
Bondy111
bondy111
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
Re: Video card
03/15/2009 12:23 AM
That card may not support dual monitors, most that do will have two of the same port, ie. 2 DVI ports. Go into your catalyst control center and see if it has a monitor 1, monitor 2 selection, and options for dual monitors.
Re: Video card
03/15/2009 5:29 AM
When I right click the desktop, click properties - settings, it comes up with a second monitor (which is currently not enabled)
bondy111
Good Answers: 97
Re: Video card
03/15/2009 5:14 AM
Hello Bondy111,
This card is indeed a double header enabling use of multiple displays.
the card has dual VGA analog support with DVI-VGA adapter or use the dual DVI ports.
Use S-Video for analog TV out
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: Video card
03/20/2009 11:48 AM
Hi Bondy,
your video card has this specs:
Display Capabilities: Dual DVI-I outputs support any combination of digital and analog displays. Independent multi-monitor resolution and refresh rate selection. Dual Link outputs ideal for driving 30-inch cinema / widescreen (2560 x 1600) displays. Maximum individual Dual Link output capable of ultra-high resolutions up to 9 Megapixels (3840 x 2400). Individual Dual Link output capable of ultra-high resolutions up to 9 Megapixels (3840 x 2400). High Dynamic Range (HDR) rendering with 8-bit, 10-bit & 16-bit per RGB color component support. Full 10-bit precision display pipeline. Advanced support for 8-bit, 10-bit, and 16-bit per RGB color component. Stereoscopic 3D output connector with quad buffer support. Dual VGA analog support. HD Component Video (YPrPb) output.
your second monitor goes into the DVI port.
HTH!
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 97
Re: Video card
03/20/2009 12:25 PM
You stated it a little better than I [post #2] maybe he'll bite
Good Answers: 58
Re: Video card
03/21/2009 4:37 AM
thank you.
BTW, I started a new thread at Software & Programming inspired by your comment on the anti-virus thing.
Register to Reply 6 comments
Bondy111 (1); bwire (2); langyaw (2); Vandarye (1)
