Previous in Forum: what is pnumatics and pneumatic controls   Next in Forum: Flow Rates
Toshiba VF S9 inverter
03/15/2009 5:31 AM
Toshiba VFD trips on earth fault immediatly on receiving a start command. What could be the reason for tripping.
Somene pls. suggest
Sandeep Waingankar
Good Answers: 54
Re: Toshiba VF S9 inverter
03/15/2009 10:50 PM
It could be that you have an Earth fault.
Check your motor and associated leads. If possible substitute another motor and leads.
Check the motor is wiired correctly.
Check if it happens when no motor and leads are connected.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
03/16/2009 4:30 AM
Yep. It's an earth fault.
03/18/2009 2:21 AM
First you read the message at the display,i think this informatio is very useful for you in order to further steps to trace the caused.
03/26/2009 9:54 PM
It might as simple as bad grounding practice. In case you are near a seashore(which I presume you are) this is very prevalent.I have seen similar problems on VFDs in paper plants near seashores.
08/14/2009 6:51 PM
you can try using a ground fault sensor
08/18/2009 12:28 PM
Register to Reply 6 comments
aikhh (1); ashelec (1); ffej (1); PWSlack (1); vinny_galbo (2)
