Previous in Forum: ERP Software for Construction / Contracting Companies   Next in Forum: xp
12 comments
laptop
03/16/2009 9:46 AM
any one can help? pls.. give me some tips in choosing a brand of laptop.
Friend of CR4
Re: laptop
03/16/2009 9:49 AM
Where are you located? What do you need it for? What are you willing to spend?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re: laptop
03/16/2009 9:56 AM
i am here now in KSA, my budget is 700$ to 800$, i am more interested in its durability, especially can stay long in electrical spikes.
Friend of CR4
Re: laptop
03/16/2009 10:02 AM
KSA? Not sure of the reference.
Still, how will you be using it. Simple word processing and web surfing or higher end programs and serious computing?
Re: laptop
03/16/2009 10:13 AM
ill used it for designing, autocadd will be the main application to used and some microsoft office. let us say which is more good for this brands LG, HP, toshiba,or dell? the main thing is the durability.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: laptop
03/17/2009 4:21 AM
Hi abmar,
for the apps you intend to use for your laptop, I'm afraid none will fall in the price range you've mentioned. AUTOCAD is usually worked with in PC workstations.
if you're looking for good robust brands, personally, I'd go for HP, but for your usage, you'll have to select the high speed processing (min 2 GHz) and display (NVIDIA GeForce 8400 M GS), at least 256 MB adapter RAM.
I can also go for TOSHIBA, but only for the TECRA model - this is industrial grade.
only these 2 can I vouch for durability.
oh, and BTW, use OpenOffice instead of M$ Office.
HTH!
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 54
Re: laptop
03/17/2009 6:34 AM
KSA = Kingdom of Saudi Arabia
HP seems to be a good, robust brand
regards,
Vulcan
Good Answers: 62
Re: laptop
03/16/2009 10:34 AM
Surviving the spikes better choice is a UPS
Do not start with brand of laptop.
Start with demands of software, do not read minimum requirements; use the web to determine actual requirements from reviews of the software.
Then take the demands your software will make and compare manufacturer's to see best cost to satisfy your needs.
Autocad and such can have very high RAM and video requirements to run *well*.
And understand, we don't know what is KAS, but warrantee is only as good as access, and there are only like 3 makers of laptops - but many names and warrantees.
Re: laptop
03/16/2009 10:50 AM
correct, but all this rams, cpus graphics all brand can met this requirement, but the point is the built-in power supplies. some of them equip with a very good anti spikes and noises which can protect the mother board, some of them are not, if i use a ups the portability of laptops will be eliminated because i will bring ups along with my laptop.
Good Answers: 62
Re: laptop
03/16/2009 11:25 AM
The vendors are not going to release much about the power supplies, but all laptops are buffered by the battery.
So maybe you pick the one with the cheapest battery and power supply replacement cost.
You *may* find some hardware information out there - tomshardware.com and others - but I do not know of any.
Re: laptop
03/16/2009 12:43 PM
thank u sir for some information.
Good Answers: 146
Re: laptop
03/16/2009 8:12 PM
I am on my second Acer because I needed to upgrade to more RAM: but the first one still works great and never flinched under LOTS of nasty power spikes in daily use for 4 years of it.
I kid you not: the old fashioned monitors you could see the image enlarging or shrunken on the spike. After a bit of this they were fried, and several hard drives were burned also. Even saw a power bar- surge protector fried.
So although I can't compare with the brands you named, I have to say the Acer impress me for their tolerance of bad power conditions.
One disappointment, the battery was only good for about 45 minutes.
incus opella
Good Answers: 97
Re: laptop
03/18/2009 3:01 AM
For durability and support I choose Toshiba especially for intensive usage.
abmar (4); artsmith (1); bwire (1); Chris Leonard (2); edignan (2); langyaw (1); Vulcan (1)
