Previous in Forum: Flow Rates   Next in Forum: Vacuum Differential Switch - Terminology
MARK-II Control Systems for GE Gas Turbines
03/16/2009 11:51 PM
Pl. give the detail of MARK-II control system if available with detail catalog.
Balbhadrasinh
Re: What is MARK-II system in Gas Turbine.
03/17/2009 2:37 AM
Contacting General Electric is your best bet. This is an old obsolete GT control system.
03/17/2009 11:48 PM
Thanks for replay,
I Know that this is a oldest system for turbine control. But the suppier maintenain it at a Black box they dont give the detail about the system hence I want to know about the system.
Balbhadrasinh
Re: MARK-II Control Systems for GE Gas Turbines
03/18/2009 6:52 AM
I think you are going to be out of luck getting much assistance. Prior to the Mark 4 the system was mostly referred to as "Speedtronics". The relaying and such used industry standard designators and should be recognizable (maybe not easily) by name.
It was a standard analog system with relay logic. I wish you luck.
If you fail to follow through, you will fail.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
03/18/2009 8:58 AM
My experience with GE turbine controllers is that they are their business and you don't get a chance to mess with them. Good luck and let us know if you find any information.
Money doesn't talk, it screams in your face.
Register to Reply 4 comments
Anonymous Poster (1); balbhadrasinhsolanki (1); betomachine (1); otha (1)
