Previous in Forum: MARK-II Control Systems for GE Gas Turbines   Next in Forum: Measuring Solar Irradiation for PV Panels
Vacuum Differential Switch - Terminology
03/17/2009 12:54 PM
chief,
what is the meaning of "reference fort" and "pressure port" on the vaccum diff. switch.
what is the port to be connect to the oil tank.
thanks,
Good Answers: 18
Re: vacuum diff. switch
03/17/2009 2:05 PM
"Chief speedtron" Please check your spelling and determine if this is what you intended to ask. Respectively, J.Conway
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
03/17/2009 10:47 PM
J.Conway,
I think you mean respectfully. You should also check your own spelling in your signature: it's opposite.
Mike
Re: Vacuum Differential Switch - Terminology
03/17/2009 3:02 PM
I would guess that the reference port should be connected to the top of the container and the preessure port would be connected to the bottom of a container where there would be pressure to measure.
03/18/2009 8:35 AM
CHIEF,
YES, THANKS FOR THE ADVICE. AND CLARIFICATION.
SPEED,
03/17/2009 11:18 PM
Hi speedtron,
guest in post #2 is correct. The reference port is your "static" side. If measuring an atmospheric liquid height, this is ported to the atmosphere. If in a pressurized vessel however, this is ported to the headspace of the vessel.
The pressure port is plumbed to the bottom of the vessel, at or below where you want "zero" to be.
Mike
Canada - Member - New Member Engineering Fields - Systems Engineering - New Member Hobbies - Hunting - New Member Hobbies - Musician - New Member Safety - Hazmat - New Member
03/18/2009 7:50 AM
I would definitely agree with Mike, I see this all the time and it's surprising how many people hook it up wrong and blow out the shaft seal on there vacuum pump, pressure has to go somewhere.
Hey, it may look confusing but it's really just Simple!!!!
03/18/2009 8:37 AM
MIKE,
THANKS A LOT, FOR THE CLARIFICATION WE TRIED IT AND ITS WORK.TILL NEXT.
THANKS,
SPEED
Register to Reply 7 comments
Anonymous Poster (1); Jerrell Conway (1); Mikerho (2); Simple1 (1); speedtron (2)
You might be interested in: Switch Boots, Audio Switch Matrices
