Previous in Forum: Wheel Motors for Electric Vehicles   Next in Forum: E-Stop Circuits and Risk Assessment
9 comments
Compressor Switching
03/17/2009 9:43 AM
I have a 240 V (2 ampere) compressor that I want to turn on and off using a voltage of 1.8V and 0V respectively. Can anyone recommend the simplest way of doing this preferably with a commercially available device.
All responses welcome.
Re: Compressor Switching
03/17/2009 10:24 AM
How about a bit of homebrew construction around this?
03/17/2009 4:13 PM
Cheers Bud, appreciated.
Good Answers: 53
03/17/2009 10:45 AM
You have not specified if voltage is 240VAC or 240VDC. In case of AC Voltage you can use a triac with low trigger voltage(less then 1.8Volts in your case)
If its DC voltage you can use a high voltage transistor directly or a low voltage transistor with a relay.
03/17/2009 11:19 AM
Thanks for that. it is 240V ac.
03/18/2009 1:56 AM
use your avilable low volt signal to make relay on and off use necessary electronic coupling cicuit . relay will ensure isolation bet low signal voltage and contact of relay in high motor voltage it a safer and dividing device to work for elect and electronics master who always urgue when results are not as expected
03/18/2009 8:15 AM
dear,
what is the frequency of the operation ? i.e. on & off perations / miniute - Hr.?
you may select solid state relay device & get it wired up by a local electric panel builder.
Exploring the Science of Electricity
03/18/2009 5:12 PM
Its 50 Hz supply. Thanks for suggestion.
Good Answers: 58
03/18/2009 8:48 AM
Assuming you have sufficient current available from your low voltage source, I would use a motor contactor and buy or make a low voltge coil for it. If you don't have the required current, you can use a relay to actuate the contactor.
03/18/2009 5:19 PM
Thanks thats helpful. I dont know current from low voltage source but would assume it to be very low as it is just output from led on pic board. supply to whole board is only 0.3 Amps.
Register to Reply 9 comments
harry potter (1); PWSlack (1); rakesh_semwal (1); staggersandfalls (4); welderman (1); YS Elect Solar Consultant (1)
