Previous in Forum: Leak Tests for In-Service Control Valves   Next in Forum: What's the Best Damper Coating for Water Pipes?
Reinforcement Pads and Self-Reinforcement Forgings
03/17/2009 10:51 PM
Where we will used self-reinforcement forgings in place of reinforcement pad.
Re: self-reinforcement forging vs reinforcement pad
03/18/2009 12:43 AM
Reinforcement pad and Self reinforcement forgings are used for the same purpose .
And now th question is when we go for RF pad and when we go for Self Reinforced Nozzles.
If your Shell thickness exceeds 50mm then you can go for Self reinforced nozzles because as the thickness increases the brittleness of shell material increases so in place of RF pad we can use Self reinforced nozzles .You can use Self reinforced nozzles for the thicknesses less than 50mm but beyond 50mm its mendatory to use Self reinforced nozzles .
06/26/2019 5:12 AM
Hi,
can I find out where you found this information?
Thanks
Good Answers: 51
03/18/2009 1:03 AM
Long Weld Neck Flanges are (may be) used in the following circumstances:
  1. There is no room to install an adequate reinforcing pad
  2. Concerns due to high temperature thermal stresses
  3. Very high pressures
  4. LWNF have better stress characteristics particularly due to external forces
  5. Saves on welding/fitting (particularly one less circ weld on a WN flange and less NDT)
  6. Concerns due to high temperature hydrogen
A little knowledge is a dangerous thing.
Good Answers: 61
03/18/2009 7:10 AM
The question I have is: Is this for a Vessel Nozzle or for a Piping Branch?
Do it once and do it right
03/18/2009 11:14 PM
Thanx to all who r given their comments,
1)the nozzle on the vessel not on the piping Branch.
AndyWOW (1); Dilip Kumar Singh (1); mechdesign (1); PennPiper (1); XMech (1)
