Previous in Forum: Reinforcement Pads and Self-Reinforcement Forgings   Next in Forum: Standard Colors for Pipe Lines?
What's the Best Damper Coating for Water Pipes?
03/17/2009 11:36 PM
Dear Sirs\ Madam,
This is my second attempt.
Please guide me in applying the Damper Coating to the pipes that carry water.
Re: Damper Coating Of Pipes for water supply
03/18/2009 4:21 AM
Well, what sort of coating is it:
  • Paint?
  • Cement?
  • Bitumen?
  • insulation and cladding?
  • grease-tape?
  • etc.
The more information and better defined the posted question, the more ideas the good folk at CR4 can throw in to provie a route to the answer.
03/18/2009 7:28 AM
I WISH TO WHICH COATING IS THE BEST ONE AND THE DETAILS OF THAT COATING BECAUSE I AM NEW TO THIS.
03/18/2009 7:31 AM
DEAR SIR WE WISH TO KNOW ABOUT WHICH IS THE BEST AND HOW TO APPLY IT FOR THE SUBJECT.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
03/18/2009 1:13 PM
Please see the comment above from PWSlack. We want to help you, but you need to give us more information. For starters, what is the pipe material? What are the service requirements like?
Good Answers: 247
03/19/2009 9:53 AM
There is no reasonable answer to your question, without our knowing many more details about the pipes, their size and material, the environment in which they are installed, and your meaning for the term "damper". As I am sure you know, ALL CAPS are considered shouting, and if you shout at someone like PWSlack, who has taken his valuable time to help you clarify your vague and poorly-constructed query, you will garner little respect here.
Perhaps you have heard the phrase, "Biting the hand that feeds you."
Re: What's the Best Damper Coating for Water Pipes?
03/18/2009 10:58 PM
Srinivigna,
I suspect that you use the term damper, but you really mean insulation. I think you want to keep the heat IN the hot water pipe, and you want to keep the heat OUT of the cold water pipe. Keep in mind, Rini, there is more than one solution
Try this, get a preformed elastomeric pipe insulation. In order to get the correct size, to fit around the pipe, you will need to know the size of the pipe on which it will be applied. The elastomeric insulation comes with a slice down one side of it so you can easily slide it on the pipe. After it is applied to the pipe, you will need to apply the tape that you bought when you got the insulation.
You did not forget the tape, did you? Good.
Now there is another option if it is available. You can put an "All Service Jacket" over the insulation. This is a stiff plastic that wraps around the elastomeric insulation. It is like a "jacket" for the pipe, hence the name. This will also need to be taped along the seam. This will keep the moisture that condenses on the cold water pipe, from dripping through.
For more information, do a search on the internet for pipe insulation.
Good luck, my friend!
Everything that we need to know about the character of advanced extra-terrestrial life is summed in the absence of open communication.
03/19/2009 2:50 AM
The water bit is easy! Where is the pipe - iin a field, on a ship, in a factory. It is where the pipe is that matters.
You can always tell the pioneers - they are the ones with arrows in their backs.
Register to Reply 7 comments
Anonymous Poster (1); Blink (1); engineermanmayer (1); hazman (1); PWSlack (1); srinivigna (1); Steve Melito (1)
You might be interested in: Damper Actuators, Coating Services
