Previous in Forum: Brake Press - Angle of the Bend   Next in Forum: Thickness Measurement of Powder Coating
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Valve Trim
03/20/2009 4:16 AM
What r valve trims?? What r different types of TRIMs?? ON what basis we differentiate the different trims??
Atul singla
Pathfinder Tags: Valve trims
Re: Valve trims
03/20/2009 4:42 AM
The trim is a way of altering the behaviour of the valve to suit the fluid and the process.
A "linear" trim will vary the valve aperture linearly in response to the input signal. It may be that this response introduces instability in the control system, in which case other trims might be more suitable. "Equal percentage" is another style of trim, for example.
Trim behaviour is a function of the shapes of the valve seat and the valve plug, which must be matched. Seats and plugs are usually changeable.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Valve Trim
03/20/2009 9:10 AM
Collectively, a valve's internal elements are known as it's "trim". Typically, valve trim includes four components: disk, seat, stem, and sleeves. The disk and seat interface, and the relation of the disk position to the seat, affect valve performance.
Register to Reply 2 comments
