Previous in Forum: ELECTRICAL ENGINEERING   Next in Forum: Tan Delta Test on Transformer Oil
9 comments
Location: Wake Forest, NC USA (in Central NC, God's country)
GFI for Fountain Pump?
03/20/2009 8:58 AM
Is it necessary to have a submerged fountain pump plugged into a GFI switch? The installer has the pump plugged into such an outlet, but the slightest amount of moisture from rain, etc. trips the switch and has made operation of the fountain inconvenient.
“Better to remain silent and be thought a fool than to speak out and remove all doubt. - Abraham Lincoln”
Re: GFI for Fountain Pump?
03/20/2009 9:58 AM
Its tripping indicates an earth fault that requires attention on safety grounds.
Inconvenient, saving life, isn't it?
03/20/2009 4:59 PM
If the GFI device is outside and is tripping, then you need to place a cover over it.
1- Gang Weatherproof Bubble Cover
03/20/2009 5:49 PM
Check Leviton GFCI Accesories. Search for 5977 and 5997 series.
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=10136&minisite=10026
03/20/2009 11:06 PM
Could a GFI breaker be used instead of the GFI outlet?
ChazL
03/21/2009 12:40 AM
Yes, you can, much more expensive breaker, but like the OP mentioned about the cover, if the receptacle (with out cover) and breaker are wired correctly, you will trip the breaker now. Put that cover on and be done.
"Real Bass Players" do not use picks
03/21/2009 6:47 AM
Yes Jimh77,
The breaker is more expensive, but the OP did not mention anything about a cover so I was just giving another possible solution adding to the one Wareagle mentioned.
ChazL
03/21/2009 11:01 AM
Yes,
It is the law, contact the AHJ and ask him to approve you're solution. (you will have to wait some hours before he stops laughing)
An alternative approach is add a junction box in the feeder line to the outlet plug and connect the cable from the pump directly to the power.
You can add clocks and other futuristic devices like to organise the functionality.
Canada - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Hobbies - DIY Welding - New Member
Good Answers: 11
03/23/2009 2:23 PM
Some GFI receptacles are notoriously poor quality, and tend to fail for no reason at all after a short time. It may be that you simply need to replace the receptacle itself. Adding the weatherproof cable housing mentioned earlier is a very good idea, but may not solve the issue if you have a bad GFI.
Cheers,
Steamerst
"You are, what you do, when it counts" - John Steakley (Armor) 1984
03/23/2009 5:25 PM
It is a real problem: the GFI becomes nervous due it's own loss and the handy neighbour takes it out.
Then the accidents happen.
Register to Reply 9 comments
Chazl (2); Gwen.Stouthuysen (2); Jimh77 (1); PWSlack (1); Steamerst (1); wareagle (2)
