Previous in Forum: Puzze Pic: What Is This Thing?   Next in Forum: Celebrating the Equinox
21 comments
Will a 50-Hz Washing Machine Work at 60-Hz?
03/20/2009 9:57 AM
Hi, Im not sure about my new washing machine (front load) I purchased in Dubai with 50Hz frequency. Im troubled if I can use it in philippines though the frequency in my country is 60Hz. Voltage is not an issue.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: 50Hz washing machine, work with 60Hz(philippines)
03/20/2009 11:47 AM
What does the nameplate say? There should be a small sticker/plate that gives the electrical details, usually on the back of the unit somewhere. The specifications section of the users manual should also tell you that information.
Tom
03/20/2009 11:50 AM
In addition to the above, how about a telephone call to the manufacturer's helpdesk, perhaps?
Re: Will a 50-Hz Washing Machine Work at 60-Hz?
03/20/2009 2:53 PM
Hi,
Your machine will run ,no problem but,as you know the speed if directly proportional to freq the speed of the motor will increase.For 60Hz the voltage needs to be increased to achieve the same efficiency.With increase in load the motor gets overloaded overheated and will burn. So the safe bet is reduce your load on your machine
pugalendhi n
03/20/2009 3:06 PM
This may or may not be true. My US made front-load washer has a three-phase motor controlled by a VFD, so as long as the VFD control, power supply, and control board are setup to run on 50-60 Hz, you would not notice any difference. But there is not guarantee that will be the case.
Tom
03/20/2009 3:51 PM
Dear Tom,
Thanks for the information. Highly appreciated.
Good Answers: 15
03/21/2009 9:36 PM
As earlier commented, going to the manufactures is the only way to know without actually trying it. If it is a modern machine it probably has a program chip which will not let it run on the "wrong" frequency. Even if the PIC chip does let it run then you may after a short while burn out the power supply circuit for the lowvoltage electronics,,,,,,,,the voice of experience.
Chas
03/21/2009 11:23 PM
So long as voltage is correct then what will happen is the motor will spin faster at the higher frequency (ie: 1450 rpm @50 hz = 1780 rpm @60 hz). This wiltend to overlaod the motor especialy if it was sized "just right for the job" to begin with. The electronics should not care as transformer stepdown voltages are not frequency related.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
03/23/2009 5:42 AM
Hi Mike,
The low voltage power in white goods is often derived from a simple capacitor dropper with a resistor and zener diode. Thus if he puts his 50Hz machine on 60Hz the cap will have 20% lower reactance. This tends to burn out the resistor or the zener.
regards
Chas
03/23/2009 11:35 PM
I have not seen this circuit, capacitor, resistor, zener diode to go from 120 V ac to say 24 V dc. If you have a simple circuit I would be interested in seeing how it works. I have seen a 3 phase transformer to 3 phase low voltage (19 V ac) then 6 diodes in a multi bridge circuit to get a very stable 24 V dc with low enough ripple that capacitors are not needed. MIKE L.
Good Answers: 15
03/24/2009 9:13 PM
Hi Mike,
the circuit I have seen used is a low value ceramic capacitor (in the nF range) from line (230V in our case), followed by a lowish value 2W resistor about (100Ω from memory) and then a zener to the neut. The few milliamps needed to run the pic chip and perhaps some transistor drivers for the relays is taken either directly from the zener, suitably smoothed, or via a 78xx regulator.
I have repaired a few where a gen has been "tweaked" to get a bit more power by increasing the revs. Non sine wave inverters and very noisy gen waveforms can also have the same result due to the harmonics present.
The motors don't seem to care too much. We do get problems with 60Hz motors being run on 50Hz where they draw a lot more current and overheat.
My advice to small boat owners and off grid systems is try to find a machine with an old fashioned motor driven programmer. They are getting difficult to find now though.
regards
Chas
03/22/2009 11:35 AM
See if the specifications tag shows a range. If it is a major brand, then it is probably designed for 60Hz, allowing a drop to 50. If it does not, then it probably will work, though the motor life will be shortened. The electronics, on the other hand, will probably be toasted forthwith.
Your alternative would be to build a dynamo, or buy an electonic converter.
How can you be two places at once when you're actually nowhere at all?
05/25/2009 8:19 PM
Hi, were you able to get an answer for this? I have exactly the same situation and I am not sure what to do. l appreciate your feedback; thanks
08/24/2010 7:24 AM
No, your drain-pump will run 20% faster and possibly create more load pressure for itself too (usually centrifugal pumps). It is likely to fail.
Many of these motors are syncronous types so may not be able to pump at the increased speeds and 'slip'
06/09/2015 9:14 AM
The answer is NO...
This is a very common problem on medium sized yachts, I have lost count of how many people have asked me for help as their washing machine has "broken".
Usually a 50hz washing machine when plugged into a 60hz supply will start its cycle perfectly, and after a while stop and beep an error code at you, you'll be stuck with a washing machine that is full of water because the sump pump isn't working.
This in fact _does_ _not_ _do_ _any_ _harm_... your washing machine is fine, but its common practice on these machines to fit sump pumps that are frequency dependant, so whilst the main motor, and all the other electronics will work at either 50 or 60 Hz, the sump pump simply will not run on the wrong frequency.
07/30/2017 4:52 AM
Hi I have common problem because I bought washing machine 50hz but it wasn't run well because we are using 60HZ frequency , the motor is designed for 50/60Hz but according to the seller the draining pump is only 50Hz that's tends why the machine had became error. I was thinking maybe I use an automatic voltage regulator designed for 50/60 Hz, do you think this will works?
Thanks
04/20/2018 5:17 AM
Im in the same dilemma, brought in the country a whirpool washing machine with a 50hz frequency. It was running well only that the drain motor would not work. Hope to hear from you bro if you were able to solve your problem. God bless.
05/19/2019 12:29 AM
I have the same issue too. It's running well. Only the draining pump doesn't work. Please post an update if you were able to solve this issue.
01/23/2024 9:11 AM
It won't do the washing 20% faster...
02/04/2024 9:49 AM
Where did all the references to Yachts / Boats get into this thread ?? The guy lived in Dubai where he bought a washing machine using 220v 50 Hz supply.
He now lives in the Phillipines where they use 220v 60 Hz supply.
Ideal would be if he posted a foto of the manufactures Plate on the back of the machine so everybody here could see if the needed info is available or details of the exact name and model of the machine so if somebody is interested enough to look at the online info available.
or the alternative would have been sell the used machine in Dubai and buy a new one in Phillipines ! and save the shipping costs !
01/27/2025 7:42 AM
If the original poster were the <...somebody...interested enough to look at the online info available...>, then there would be no need to create this thread.
01/27/2025 11:16 AM
True but obviously he didn't think to do that and it did give us the chance to make our comments.
Register to Reply 21 comments
Anonymous Poster (4); capblanc (2); Ferdie911 (1); gbequizo (1); hchammas (1); Jerry New Hampshire (1); MIKE L. (2); OceanicWanderer (1); PWSlack (3); tdesmit (2); The Wizard (2); yellowh28 (1)
