Previous in Forum: ELECTRICAL   Next in Forum: out put of panel
Convert a split ring induction motor to a squirrel cage?
03/21/2009 8:10 AM
I wanted to know whether we can convert a split ring induction motor to a squirrel cage one.
Good Answers: 103
Re: Hai all
03/21/2009 8:19 AM
Why not ?
Take out the rotor and replace it.
But then why do you want ? buy it, that will be cheaper.
Good Answers: 804
Re: Convert a split ring induction motor to a squirrel cage?
03/21/2009 7:36 PM
Assuming you mean "slip ring" not "split ring", there is an issue to investigate first.
There are two kinds of "slip ring" motors, totally diferent from each other. A Synchronous motor uses slip rings for the rotor field connections, and a Wound Rotor Induction Motor uses slip rings for the rotor winding resistance connections. If you have a Synchronous motor, you cannot change that into an induction motor.
If you have a Wound Rotor Induction Motor, you can "convert" it, but it is rarely as simple as some people think. If all you do is short the rotor connections, the result is a Squirrel Cage motor with extremely high starting current and low starting torque; exactly the opposite of what most people need. It's better to leave it like it is and either use a Soft Starter to reduce the steps of resistance down to one, or use a very good VFD and short the rotor connections. If you don't know whaqt all this means, by all means stay clear of doing it.
Good Answers: 103
03/22/2009 12:42 AM
Just check up the wiring principles (internal - that is windings etc and their properties and working principles, characteristics curves and why they are different ) of SRIM and SQIM and you will know why it should not.
03/23/2009 4:17 AM
It would be easier to replace the motor and keep the unmodified one as a serviceable spare.
Register to Reply 4 comments
JRaef (1); PWSlack (1); sb (2)
You might be interested in: Metal Ring Seals, Induction Heaters, V-ring Seals
