Previous in Forum: Vortex Breaker Plate thickness   Next in Forum: Air consumption
NdFeB magnets strength Dimensions(1 x 2 x 0.5)inches
03/22/2009 8:23 AM
Hallo all
I have one simple question? If you have a block of NdFeB 1 x 2 x 0.5 (inches) magnet, N36, How much weight could you expect to lift off the ground with it. i hope my question is not so shallow. please help, just an apporoximation will be fine with me. i just need a rough idea!!
Pathfinder Tags: magnet
Re: NdFeB magnets strength Dimensions(1 x 2 x 0.5)inches
03/22/2009 11:05 PM
oooh - rare earth magnets! these things are cool.
Could you be a little more specific on the object you are planning to lift with the magnet? While your magnet will be quite strong, its adherance to another material under load will be highly dependant on the magnetic and geometric properties of the material you intend to lift. If it has a low threshold of magnetic saturation, (e.g. plastics, wood etc), you won't be able to lift anything.
A rough guess using a 3mm, square steel plate would be 4-10 kg
hope that helps.
Good Answers: 109
03/23/2009 4:43 AM
Hi,
not a good idea.
FEM calculation needed.
And additional data: which NdFeB, maximum temperature, roughness of contact, pure force or some torque (usually a lot), magnet backed with iron or even better U-shaped flux guide.
Make a test.
RHABE
03/23/2009 9:13 AM
thank you for your input. the magnets are to be used for constructing an alternator for a wind turbine. I am planning to import them from Sweden to Kenya. My brother in law is insisting on knowing the weight they can lift. that's why am asking. I know it is dependent on temperature. is 10 kgs OK?
Thanks again.
03/23/2009 10:43 AM
http://www.buntingmagnetics.com/neodymium-magnets/
80 lbs (about 40 Kg) according to this manufacturer.
03/24/2009 8:36 PM
There is no answer to your question. If it is a permanent magnet, you can attach a steel plate the same size as your magnet width length and thickness with a hook in the center, make sure the hook is in balance with the center. Start out with a small amount of weight, then gradually add weight and it increases the magnet's force. thus increasing the magnet's weight capability.
Anonymous Poster (2); Randall (1); RHABE (1); tileandhardwoodcreations (1)
You might be interested in: Industrial Magnets, Rare-Earth Magnets, Magnet Wire
