Previous in Forum: NdFeB magnets strength Dimensions(1 x 2 x 0.5)inches   Next in Forum: How can i make supercharger for 4hp-100cc-2 stroke?got idea please give me sugg.
Air consumption
03/22/2009 10:17 AM
Dear sir,
Iwould like to know the following.
1. We are using a spray nozzle system, in which air is continuosly delevered through 64 nos. of nozzles, through a pu 6 hose at pr. of 6kg/sq.cm. What will be the required cfm for this?
2. If we use a 32mm MS pipe line to take air for the distance of 150 meter,the total vol. is 0.1206 cu.meter and the cfm is 4.2 is it correct?
3. Can we connect the line (32 mm) directly to the reciver tank which comes from the compressor. Assume that the lines from three different capacity compressor, are connected in common header(32 mm)and then go to the reciever tank is this method is ok ?
Please give the details regarding this as early as possible.
thanking you
yours
GURURAJA.S
Re: Air consumption
03/22/2009 1:52 PM
Bud Trinkel
Re: Air consumption
03/25/2009 1:26 PM
1. Does the nozzles need 6 kg /sq.cm pressure ? Please find out that. Most likely ,it will be much less. So try for for other means like twin lobe compressors/roots blower etc.
2.Very simple calculation !and mix up of metric and fps. Show how you arrived at the the volume per minute.
3.First find out ,do you need 6 kg pressure every where ? if not supply some area with lower pressure from the compressor. for every 5 psi drop in compressor peak pressure you can save about 2 % of energy . There is no problem in going for common header , but look at the sizings of header,bends, reciever capacity vis a vis compressor capacity, peak pressure and unloading pressure of each one ,type of compressor ,screw/reciprocating etc.
Re: Air consumption
03/28/2009 9:11 AM
Dear sir ,
Thank you for sending your suggestions, and replay to your msg.1 &3 ,the poeple who are using this spray system belive that, they required min. pr. of 6kg/sqcm.other wise it will not coat starch on the paper which movws along with felt.
Regarding arrangement of pipeline i will send photos of the line then you can able to find out better one.
Register to Reply 3 comments
Anonymous Poster (1); BudT (1); gururajashailarao (1)
