Previous in Forum: Axial Fan efficiency vs Centrifugal fans efficiency   Next in Forum: selection of valve material
10 comments
Syntron Vibrators
03/24/2009 12:32 AM
I like to get some info on syntron vibrator. It's a vibrating tub that moves parts to an automatic assembly machine.
How to make one, who makes them , where to buy it .
Any info is appreciated.
Re: syntron/vibrator
03/24/2009 2:51 AM
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Syntron Vibrators
03/24/2009 9:36 AM
Google is your friend.
http://www.fmctechnologies.com/MaterialHandling/LinkBeltAndSyntron/Products/MaterialFlow/SyntronBinVibrators.aspx
Good Answers: 204
03/25/2009 2:22 PM
Here is a discussion on vibratory feeders, and how they work. CR4 is your friend too!
Chris
03/24/2009 11:07 PM
AAAARRRGH!!!
I just spent half an hour describing how to make one and the stupid spell checker tossed the whole thing!
I'm going to bed.
Logic is the art of going wrong with confidence. -- Morris Kline
03/25/2009 7:48 AM
Try this site they make vibratory feeder systems
http://www.arthurgrussell.com/
03/25/2009 1:31 PM
Thank you all for your input but my initial question about a moving part syntron is not quit correct. Syntron came to mind because it vibrates. All I want to do is,mount some kind a vibrator to a 12 or 16 in dia disk mounted on some kind of base, table, tripod --.I opened all the e-mails that where offered .
03/25/2009 3:17 PM
They use Syntron feeders in asphalt batch plants, in the aggregate cold feed systems. They are mounted on the bottom plate near the exit spout of the fine aggregate hoppers in the cold feed. This prevents "bridging" of the material at the exit of the hopper and allows a uniform feed to the belt conveyor. This application is physically similar to yours in that the vibrating device is mounted on a plate. A supplier of asphalt batch plants and equipment can locate one.
Never underestimate the power of stupid people in large groups.
03/25/2009 7:39 PM
Can you please expound? Do you want the disk to vibrate, or is the disk just a base for the vibrator? Are any piece-parts to be moved?
If you give us a full explanation of what you want to do, you're much more likely to get a suitable answer. Someone may even come up with a simpler & more cost-effective way of getting the effect you want.
03/26/2009 3:51 PM
John DJ.
I thought I made it clear. All I want is to shake a disk horizontally that is mounted on springs. Now you ask how thick is the disk, 1/2 to 5/8 in can be made of , wood, aluminium or plastic.
The question is.
What type and size is sufficient to shake this disk when the vibrator is mounted on the side of the disk. It will NOT be used to move any parts.
04/24/2010 9:22 PM
Did you want it to vibrate linearly or rotationally?
How far do you want it to vibrate and at what frequency?
Register to Reply 10 comments
Anonymous Poster (1); chrisg288 (1); GordieGii (2); JDknut (1); JohnDG (2); pastler (2); Steve Melito (1)
