Previous in Forum: Caloric Factor (Kc) and Fouling Factor   Next in Forum: Nitric Acid or Citric Acid for Passivation of Stainless Steel?
Socket Weld Fittings
03/26/2009 8:10 AM
Why use socket weld fittig for small line. Can't use buttweld fitting?
Re: Socket weld fitting
03/26/2009 8:14 AM
Butt-weld is not available for plastic pipes.
Socket weld in electrically-welded pipes reduces the risk of the weld bead causing an obstruction to flow.
Re: Socket Weld Fittings
03/26/2009 3:13 PM
You can also use buttweld (steel) - please see previous discussions regarding the differences/issues:
http://cr4.globalspec.com/thread/27366
http://cr4.globalspec.com/thread/31395
