Previous in Forum: Washer and Lock washer   Next in Forum: Help Wanted: Intraocular Lens Manufacturing
Distribution Transformer - Tap Changer is Burned
03/30/2009 10:07 PM
dear all
found distribution transformer tap changer was burn at nominal pin for phase A & C, not other electrical equipment damge reported by local utility. i would like to know the reason of burn of tap changer nominal pin and the rest of part in good condition. my ideal is sabotage, but no evidence to prove. any ideal
regards
Pathfinder Tags: Distribution transformer
Re: distribution transformer tap changer burn
03/31/2009 3:33 AM
  • Loose connection?
  • Overcurrent?
  • Someone's had a bonfire?
You might be interested in: Burn-in Test Equipment, PIN Diodes, IC Pin Probes
