Previous in Forum: Test Ring Thickness for U-Tube Bundle Exchanger   Next in Forum: Supersonic Air Flow?
METALS
03/31/2009 7:04 AM
DEAR all you know wich metal alloy expend in dimension with the passeg of time .it is not related with thermal expension.
Good Answers: 103
Re: METALS
03/31/2009 7:16 AM
At least one I know : Steel
If there is a retained unstable austenite - then by aging it decomposes and has a consequential volume expansion.
There may be other alloys too
Re: METALS
03/31/2009 3:15 PM
Aluminium has a little known hygroscopic property when used in certain environments. It has a tendency (under worst case conditions) to absorb moisture in the air and swell, greatly reducing its current carrying capacity. This phenomena can be seen rather clearly when you stand under aluminium transmission lines when its raining (you get less wet than if you stand to the side). Many people believe that the sheets of insulation around aluminium busbars are to insulate the busbars to prevent flash over due to the voltage, in actual fact they are there to create a nice warm environment to dry the aluminum out if it absorbs too much moisture. This is also why you will sometimes see heaters in cabinets containing aluminium bus work.
Note - as a power engineer one of the FIRST things you are taught is to never, ever under any circumstances go out and try to dry a water-laden aluminium bus bar with a towel (this is also grounds for instant dismissal).
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: METALS
04/01/2009 9:55 PM
Dismissal from work or the Human race???
Sapper
It's all about the Boom! - MythBusters
Good Answers: 103
Re: METALS
04/02/2009 12:13 AM
Nomination for darwin Awards ?
jack of all trades (1); Sapper (1); sb (2)
