Previous in Forum: Signal   Next in Forum: MODULATING CONTROL SYSTEM
What's the Best Temperature Controller?
03/31/2009 11:27 AM
Who makes the best auto-tune temperature controller? I run temps from 350 to 1100 F.
Pathfinder Tags: Temperature controllers
Re: Director of Technology
03/31/2009 11:45 AM
They all use the Ziegler-Nicholls tuning criteria in their auto-tune algorithms, so it is not possible to say.
Hobbies - DIY Welding - pipewelder
Re: What's the Best Temperature Controller?
04/01/2009 11:13 AM
Hello, I would recommend a Watlow controller. I use a Watlow controller, S thermocouple, and a Watlow 75 amp Din a Mite solid state relay on my main glass furnace and I have had very good results with it. I use the cheaper temp. controllers (Ebay for 50 bucks) with K thermocouple on my lower temp annealing ovens and have had good service from them also. I use the Watlow on the main furnace because I can't afford to have a problem with it like I could on the annealers. I guess it is all up to how much you want to spend and how critical it is to you. The good thing about Watlow is that they have a number you can call and get help if you have a problem and they also come with a very good manual.
pipewelder
South Africa - Member -
Good Answers: 12
04/02/2009 1:31 AM
Hi there,
Impossible to answer as we all have different preferences.
Besides this - alot will depend on your process dynamics as well as the area classification etc. Do you want a stand-alone controller? Are you willing to put in a new DCS/PLC? Is your instrumentation in 100% condition?
Personally - I do not like auto tuners. You tune a loop for the current instrumentation and process. As your valve or transmitter starts to go out, you will notice that the loop tuning is no longer working properly. This is a good sign for maintenance. With auto tuners - you do not notice this degradation as easily.
With that said, if I was actually forced to use a auto-tuner - Siemens PID self tuner. Beware that you will need to use the Siemens software for this.
If you are looking for a very good tuning package - try Protuner. You can get more info at www.controlloop.co.za
Regards,
Craig
Register to Reply 3 comments
craigza (1); pipewelder (1); PWSlack (1)
