Previous in Forum: Air Pressure, Velocity and Flow   Next in Forum: Designing Supports for Pressure Vessels
9 comments
Noise Reduction
04/02/2009 8:04 AM
We are building an office very close to our workshop. Is there a way to find out how much thick glass needs to used for a fixed window for reducing noise. Am not sure of the decibel level to be reduced but to give you an idea of noise around ours is an steel fabrication workshop.
Re: Noise Reduction
04/02/2009 9:03 AM
Radio broadcast studios have a similar problem. They use glass panes, spaced some distance apart and not parallel, and the inner walls of the windowframe are lined with sound-absorbent materials. Try that?
Re: Noise Reduction
04/02/2009 9:08 AM
Like wot PW says...it's not so much the glass as the gap between.
Re: Noise Reduction
04/02/2009 9:17 AM
If you remove the air from that nonparallel gap between your window panes you will get better acoustic isolation.
How much is the question. That's a hard one to answer.
Material density (high) and vacuum both help, but each shop will have a unique acoustic signature.
If you haven't already, talk to a window fabricator.
Re: Noise Reduction
04/02/2009 9:46 AM
<...If you remove the air from that nonparallel gap between your window panes you will get better acoustic isolation....>
Just make sure the glass is thick enough to support itself for this application otherwise someone is going to have a smashing time!
How much noise comes through the wall instead is now open to question.
Good Answers: 266
Re: Noise Reduction
04/02/2009 8:04 PM
An insulated glass unit filled with an inert gas like Argon.
Re: Noise Reduction
04/03/2009 1:20 AM
Hi...
you may try this " laminated DGU glass units consisting of two laminated glass units separated by air gap which comprises of outer 6mm thk Heat strengthened clear glass or tinted glass + 1.14mm thick P.V.B. lamination + 6mm thk Heat strenghthened clear glass+ 16mm wide air gap duly filled with compressed argon gas+ 6mm thk Heat strengthened clear glass+ 1.14mm thick P.V.B. lamination + 6mm thk Heat strenghthed clear glass. All processing to be carried out as per relevant IS / International codes and practices ".
We have used it as we are near a railway track. The noize level in the room does not go above that of the room airconditioner.
Anil Tiwari
Re: Noise Reduction
04/03/2009 4:21 AM
Note the comment above about high density materials. Hopefully the walls are already brick. If there is a door between the noisy area and the quiet area consider using a solid wood door, not a lightweight door. Watch out for air gaps or other areas of low density material between the noisy area and the quiet area. You will probably not be able to eliminate some air gaps but take steps to reduce them to a minimum (use seals round the door frame and consider a raised step at the door for the bottom of the door to seal against). Put as much sound absorbing material as possible in the office area (soft furnishing, acoustic tiles on the ceiling, soft material on the walls).
Re: Noise Reduction
04/03/2009 7:13 AM
I have some experience in this field.
Two good quality windows of any type, single glassed, even installed parallel, but better a little out of parallelism, at 12 to 15 cm away each from the other, will insulate as well as the best double or three glassed window.
The sliding type ones are the more suitable for this double window installation.
The most important is to seal very well, with polyurethane for instance, the frame of the windows against the wall.
Arturo
QUIMERA
Re: Noise Reduction
04/03/2009 7:48 AM
Average airborne sound insulation, averaged over the frequency range 100 to 3150 Hz
for fixed windows: 10 mm glass-200 mm gap- 6mm glass well sealed, lined reveals = 44dB
(ref. page 253 "Acoustics, Noise and Buildings - Parkin, Humphreys & Cowell")
Cheers
Vince
Register to Reply 9 comments
aniltiwari (1); Anonymous Poster (1); ARTURO (1); lyn (1); ozzb (1); pswengineer (1); PWSlack (2); user-deleted-1105 (1)
