Previous in Forum: Designing Supports for Pressure Vessels   Next in Forum: How to Determine Test Pressure
Small-Volume Crude Oil Pump
04/02/2009 9:06 AM
What is the most suitable pump to pump 0.92 cubic meter of crude oil over 210km? Is diaphragm pump possible to pump at this capacity?
Re: crude oil pump
04/02/2009 9:13 AM
For such a small volume as 0.92m3, would it be better to truck it, rather than build a pipeline? The volume of the pipe might be bigger than the volume of the crude oil!
If not:
  • What is the diameter of the pipeline?
  • What is the difference in elevation?
  • What is the intended flowrate of this 0.92m3?
  • What is the density?
  • What is the temperature?
  • What is the viscosity?
Following fluid friction calculations, out drops the kW rating of the pump, which has a bearing on pump type selection.
Good Answers: 62
Re: Small-Volume Crude Oil Pump
04/02/2009 12:32 PM
Barely enough oil to wet a hose that long, much less a pipe!
04/02/2009 7:24 PM
0.92 cubic meter total? or 0.92 cubic meter per second? per hour? per day?
I think you need to rephrase the question...
04/02/2009 11:30 PM
In addition to the other good questions posted by others. My question is why on earth you would wish to pump such small volume of oil over such a long distance?
Cheers,
Bloefeld
bloefeld
Register to Reply 4 comments
bloefeld (1); edignan (1); PWSlack (1); Steve S. (1)
You might be interested in: Oil In Water Monitors, Oil Sensors and Analyzers
