Previous in Forum: Fault Message for PLC S7-300-2DP   Next in Forum: VFD Motors
13 comments
Good Answers: 244
Sizing a Control Transformer for Various Loads
04/06/2009 9:39 AM
Can anyone help me to size the control transformer for the following loads?
Total sustained load = 8.1 A
Total inrush load = 41 A
It will be used for the closing control circuit of a LV breaker.
Is 2KVA transformer OK?
Thanks,
- MS
Re: Sizing a Control Transformer for Various Loads
04/06/2009 10:01 AM
What voltage?
Good Answers: 244
04/06/2009 1:01 PM
120 VAC
04/06/2009 11:23 AM
8.1 amps x voltage = VA or watts. Use this figure to size the transformer.
04/06/2009 10:41 PM
Yes it's more then enough
04/07/2009 1:40 AM
1 What are the voltages on the primary and secondary side?
2 Will there be any other loads on the transformer at a later date?
3 Will the breaker be operated occassionally or rather frequently?
4 Any other relevant details?
SAMUEL CHELLIAH
04/07/2009 1:46 AM
1. 110kV/33kV
2. No
3. It's regular operating breaker
04/07/2009 2:15 AM
I have enclosed the clculations. Transformers have to be designed for the starting currents. If you need any further clarifications please let me know
SAMUEL CHELLIAH
Inrush current in amps41
Sustained current in amps8.1
Secondary voltage in kV33
Ratio of inrush to sustained current5.061728
Sustained kVA (8.1*33)267.3
Inrush kVA (41*33)1353
TRANSFORMER RATING
CRITERIA 1 - 15% margin on operating load in kVA1555.95
CRITERIA 2 - Recommended transformer rating with 1.41894.20
times over load capacity for 1 min as per IS : 6600
Hence, theoretically required transformer rating1894.20
From the above, I'll suggest you can go in for a 1750kVA transformer
04/07/2009 2:22 AM
Sorry!!
Mr. Samuel , I have given voltage parameters for sensitive earth fault calculations not for Transformer sizing
Pls. ignore this
04/07/2009 8:55 AM
Mr Krishna,
Can you give me the primary and secondary voltages of the transformer? this is important to fix the rating of the transformer
Good Answers: 244
04/07/2009 5:30 PM
The primary is 480V and secondary is 120V
Secondary loads:
Control Transformer size ?
04/08/2009 12:56 AM
I presume the currents you have indicated are the secondary side currents
Secondary voltage in V120
Sustained kVA (8.1*120/1000)0.97
Inrush kVA (41*120/1000)4.92
TRANSFORMER RATING
CRITERIA 1 - 15% margin on operating load in kVA5.658
CRITERIA 2 - Recommended transformer rating with 1.4 times overload for 1 min as per IS: 66007.9212
Hence, theoretically required transformer rating7.9212
From the above, I'll suggest you can go in for a 8kVA transformer
SAMUEL CHELLIAH
04/08/2009 7:52 AM
dEAR,
Ratio starting Amp / Normal Amp = 41/8.1 = 5
As any transformer can take up the starting current 6 - 8 times , thermal effect is neglected.
You require transformer to suit 8.1 * 120V = 972 VA.
Add 15% safety for ambient variations, I suggest to go for 1.2 KVA rated transformer.
Exploring the Science of Electricity
04/09/2009 12:26 AM
I was dealing with lift irrigation schemes where the motors are DOL (direct on line) starting. The manufacturers recommended the transformers should be rated for the starting current and not the rated current. In my experience I have seen the transformer voltage dropping drasticallyduring starting if not designed for the starting current. Hence the transformer should be designed for the starting current
SAMUEL CHELLIAH
Register to Reply 13 comments
harry potter (1); msamad (2); PWSlack (1); Samuel Chelliah (5); VC KRISHNA (3); wareagle (1)
