Previous in Forum: PCBs and Soil Remediation   Next in Forum: Solar Reflective Index (SRI) of Galvolume
13 comments
CAS Number for Bleaching Powder
04/06/2009 1:22 PM
Good day, folks.
I've been having a spot of trouble locating a valid CAS number for a substance with the chemical formula Ca(OCl)Cl; informally referred to as "Bleaching Powder." The difficulty for me comes from the fact that I cannot find an MSDS which explicitly names the two of these on the same sheet. In that spirit, I would like to confirm that this substance is indeed properly named "Calcium hypochlorite."
Now, before simply laughing at this query, please recall that so-called Bleaching Powder is also commonly referred to as any one (or several) of the following:
Calcium oxychloride
Ca(OCl)Cl
2Ca(OCl)Cl
Ca(ClO)Cl
Ca(OCl)2
Ca Cl2O2
Ca(ClO)2
My ancient high school chemistry seems to fail me here.
Please help?
Thanks!
Re: CAS Number for Bleaching Powder
04/06/2009 2:56 PM
Hi IC,
It's called calcium hypochlorite:
http://www.jtbaker.com/msds/englishhtml/c0418.htm
Mike
04/06/2009 3:12 PM
Thanks Mike.
So, in other words, CaCl2O2 (as presented in the MSDS which you linked) should be considered identical to Ca(OCl)Cl; thereby clearing up the whole nomenclature issue.
Is this true?
Thanks again . . .
04/06/2009 3:55 PM
I have always seen bleach bottles with "calcium hypochlorite" listed as the main/active ingredient, with the formula being CaCl2O2. The formula Ca(OCl)Cl is not the same (lacking an Oxygen) formula. However, the long list you gave in your original post leads me to believe that there are different "interpretations" of what the exact chemical formula is.
What application is this for? Maybe that would clarify things a little.
Mike
04/06/2009 7:17 PM
Hmmm... I thought the extra O would be an issue. This substance is confused in the notation --
Well, if it helps, here's what I'm after:
  • Ca(OCl)Cl + H2SO4 --> CaSO4 + H2O + Cl2
The desired gaseous endproduct: Pure, simple Chlorine on-demand; with a minimum of apparatus. And yes, I do remember to AAA
Now, if we use "Calcium hypochlorite" (represented as CaCl2O2 in the Baker MSDS), won't we wind up with a mixture of gasses in place of neat Chlorine as the end product?
Specifically, where will the extra Oxygen wind up? Chlorine monoxide?
Thanks again.
04/07/2009 1:37 AM
OR, you could have something like this:
4CaCl2O2 + 2H2SO4 ---> 2CaSO4 + 2CaO + 4Cl2 + 3O2
What do you think?
Mike
04/07/2009 3:04 AM
Er, wouldn't an excess of sulphuric acid react with the CaO to make more CaSO4?
04/07/2009 12:48 PM
Hi PWSlack
I don't think so, but maybe. I'm sure that there other reactions going on as well.
I was just trying to make the dang stoichiometry work!
Mike
04/07/2009 4:07 AM
The reaction looks a bit dangerous
Try going to:
http://cameochemicals.noaa.gov/
and mixing Sulphuric Acid and Calcium Hypochlorite.
If you don't know it, the website above is very useful for properties, hazards and possible reactions if you mix two chemicals
04/07/2009 10:14 AM
Thanks for weighing in on this, folks. I do appreciate the helpful input
Thanks, tesser, for the link. One more resource to add to the collection --
However, don't you think that the reaction should be safe with ordinary care, as long as it is not rushed?
@Mikerho:
Your new eq doesn't seem to be balanced.
In any event, I'm concerned about the excess free Oxygen winding up in the end gasses. Then again, would an actual reaction as PWSlack suggests take the extra O up into the resultant CaSO4? Could this be the real case?
Alternatively, here's a possibility which I'd like to run past everyone concerning the apparent difficulty in nailing down a source/CAS# for actual Ca(OCl)Cl in this application:
  • CaCl2O2 + H2SO4 --> CaSO4 + H2O2 + Cl2
Is this the reaction which we'd be actually seeing with CAS #7778-54-3 (Calcium Hypochlorite) in place of Ca(OCl)Cl in the above equation? If correct, it'd appear that the extra O would simply be swept into solution with the water; eliminating any contamination of the gaseous Cl2 endproduct. And, if this is indeed the case, would CaSO4 be quietly settled sitting in a bath of hydrogen peroxide?
Is this how things would actually turn out by substituting CaCl2O2 in the mix???
Thanks again!
04/07/2009 12:55 PM
It is balanced, but I don't know if I predicted the products accurately, and I can't really say for sure that you would get H2O2 as a product. I've been too long away from chemistry.
As a safety concern, (http://cameochemicals.noaa.gov/reactivity#Pair_1) what conc. of H2SO4 are you thinking of using?
Mike
04/07/2009 2:55 PM
Try Google-ing your compound. Put in the formula. They have a partial print of a 1920's book on industrial chemistry by Mann which I think will answer your question.
04/07/2009 3:33 PM
@Guest:
I found this by Martin.
If you're still here, is that the citation which you saw?
Thanks . . .
04/10/2009 10:22 AM
@All:
Thanks again for your help; and have a good day
Register to Reply 13 comments
Anonymous Poster (1); Insatiably_Curious (5); Mikerho (5); PWSlack (1); tesser (1)
