Previous in Forum: am designing an automatic pump control system & am using stainless steel probes   Next in Forum: what is the purpose of gradient tests in transformers and how can we done?
8 comments
Voltage Setting for a Single-Phase Power Supply
04/08/2009 7:58 AM
I am buying a high speed spindle from a company in Italy. They have two different voltage options available for the spindle which are either 220 or 380. I operate my CNC router using a single phase power supply. Can anyone confirm which voltage option I should go for.
Re: Which voltage setting for single phase supply?
04/08/2009 8:01 AM
Single phase voltage will be obviously 220 VOLTS AC. 380 is a three phase voltage
04/08/2009 8:05 AM
You almost certainly need the 220V version - but where are you located? What's on the rating plate of any other equipment you're running from this supply?
04/08/2009 8:15 AM
My business is located in the UK.
04/08/2009 8:20 AM
220V. (It should probably be offered as 230V, as Italy (along with the rest of us) have standardized! The 230V spec has wide enough tolerances to include the old UK 240V and the 220V used by some European regions.)
Good Answers: 38
Re: Voltage Setting for a Single-Phase Power Supply
04/08/2009 11:59 PM
If your workplace accomodates 3-phase supply then i would go for the 380Volt solution, if you have only 220Volt then go for the 220Volt option.
04/09/2009 6:20 AM
220v
04/09/2009 11:48 AM
You should let us all know what kind of CNC machine you have...
--->I'm a cnc hobbyist myself<--- I have built a 3foot by 6 foot heavy duty machine for milling metals. I used 1600oz/in stepper motors and geckodrive G202 drivers.
Good Answers: 12
04/11/2009 7:32 PM
Italy => UK... definitely go for 220v. I assume there would be no 50Hz / 60Hz motor conflicts here.
I asked my neighbor (an electrical contractor) what it would take to have 3 phase installed here. His reply was "How many thousands of $$ are you willing to pay for it?".
So go for 220.
Bill
Register to Reply 8 comments
Andy Germany (1); Anonymous Poster (2); Epke (1); Icestation2 (1); JohnDG (2); Sciesis2 (1)
