Previous in Forum: Power Factor Improvement and Energy Savings   Next in Forum: NETWORK THEORY 1
STATISTICAL METHOD –DESPERSION USING CODING PROCEDURE
04/09/2009 3:45 AM
the length of 50 copper plugs gave the following frequency distribution
length x (mm) 14.0-14.2 14.3-14.5 14.6-14.8 14.9-15.1 15.2-15.4 15.5-15.7 15.8-16.0
Frequency f 2 4 9 15 11 6 3
(a) Calculate the mean and the standard deviation
(b) For a full batch of 2400 plus, calculate
i. The limits between which all the lengths are likely to occur
ii. The number of plugs with lengths greater than 15.09mm.
This discussion was "closed" on 04/09/2009 7:30 AM. No new comments are allowed.
Message from admins:
CR4 is not a homework cheat site.
Good Answers: 97
Re: STATISTICAL METHOD –DESPERSION USING CODING PROCEDURE
04/09/2009 4:14 AM
When is this homework due?
04/09/2009 4:49 AM
this saturday, 11/04/09.
Good Answers: 97
04/09/2009 5:46 AM
Although we sometimes itch to help with homework we don't because it will defy the object of your studies,
What you should do is to open your handbook or class notes and search for the code words in the question.
Your answer will be there.
Register to Reply 3 comments
