I had a thought about a way to harness tidal energy. I've looking at horizontal blades for a wind generator. The thing that I liked about this type of blade design is that it will pick up the wind from any direction. Now I don't want to get into the pros and cons of this design with the wind. Lets keep this to the water.
My thought was using this in some kind of tidal application. The thing that I've seen with the tidal generators is that they have to turn around depending on if the tide is coming in or out. Well what if you used a squirrel cage type design in the water the wheel would always be turning in the same direction no matter what the direction the water was moving. It should be a pretty simple thing to build and you might be able to use some sort of anchored platform to hold the generator and the squirrel cage would be underwater. I can see how this blade design wouldn't be as effecient as a propller type of blade. But it can be nice and long and build very cheaply. Because it could be built with a small diameter but any length you want then you could put it in some pretty shallow water. Much more shallow then a prop could be.
I live in the midwest so I'm about as far from the ocean as you can get so I don't know much about the ocean. Maybe this isn't new and it is already being used. But I haven't seen anything on something that looks like this and I try to keep an eye on alterntive energy sources. Is this a dumb idea or not? I'd like to hear what others think of the idea.
