To Whom It May open the discussion:
Scenario: There is a set of natural gas pipes in an underground network and several lightning protection rods from surge protections in the same area.
Questions:
Q1: What is a minimum distance (in the ground) between lightning protection grounding rods and a natural (explosive) gas pipe? Gas Company do not allow bonding pipes to grounding systems.
Q2: What is a "geometrical characteristic curve"/ functions as: Voltage = function of distance from discharging lightning rod [V= f(d)]?
Q3: What are the international codes and regulations of these protections? Probably: Electrical - Lightning protection - natural gas explosion zones etc.?
Q4: Are there different USA & Canada regulation requirements that the international ones?
Q5: Do you know any examples of gas installation (especially underground) explosions from the lightning strikes? Any links?
Q6: Are there different requirements depending to the location? E.g. using a map of lightning strikes intensity per year?.
Q7: Any addition thoughts, opinions, observations, experience?
Bob
