Is it possible to make a flying shear that uses only mechanical means to track and match the speed of the product it is cutting?
I have a circular cutting wheel that only needs to rotate clockwise a 1/4 turn for each cut. But, it will need to move on a guide at the same speed as the product while it cuts. Then it will need to return to start the next cut.
I know I can spend about $30K for a 2 axis electronic system of drives and motors, but I was wondering if there is a more primitive way of doing the same thing.
I have compressed air and plc logic available. I would even be satisfied with a system of limit switches and air valves. I think it would be alot cheaper.
