Previous in Forum: Material Hardness   Next in Forum: Why Does Shaking Cause Expansion?
9 comments
Does Pyrex Glass Warp?
04/14/2009 2:15 PM
In the course of massive holiday cooking last weekend, we noticed that several flat rectangular pyrex baking dishes had developed ovoid raised areas in the middle of the bottom of the dish. Corning claims that Pyrex never warps. We are wondering about 2 things: What caused this? and Are these dishes now dangerous to use, e.g. ready to explode in the oven?
wldnwly
Pathfinder Tags: pyrex glass heat
Good Answers: 101
Re: Does Pyrex Glass Warp?
04/14/2009 4:16 PM
Interesting, I've never seen such a thing. I would suspect if the raised portion has any void of material (IE a bubble), It could definitely present a danger of explosion due to the expanding gasses trapped within. I'm curious to hear any explanations anyone has on the issue. I've owned my fair share of Pyrex cookware and have never seen that happen, and you say you have "several" dishes that have these symptoms. I would have to guess that it might be a more local problem with some other aspect causing such a phenomenon, rather than the dish itself.
04/14/2009 4:37 PM
One raised area per dish?
04/14/2009 5:18 PM
yes, roughly in the center, about 3 X 6 inches, roughly oval
wldnwly
04/14/2009 5:38 PM
Hi wldnwly,
Of the ones I have had, at least some of them come with the center raised a bit - just like you have described. Maybe it's by design or how they are processed. Are you sure that they were not like that before subjecting them to heat?
Mike
04/15/2009 8:59 AM
Interesting - they actually weren't mine, but a relative's where I was helping out, so I didn't see them until the raised area was pointed out. However, some of the pans did not have the raised area, so I don't think they are deliberately made that way.
wldnwly
04/14/2009 7:09 PM
Are you sure they're the genuine article (not rip-off copies)?
04/15/2009 7:21 AM
He meant, "are you sure they are not made in China?"
04/15/2009 8:58 AM
If somone made a knockoff of pyrex they would probably use soda lime (window glass). Properties of Pyrex: Softening Point: 1510 °F (821 °C) Soda Lime: Softening Point (ASTM C 338) 1319°F (715°C). So for oven temps it probably wouldn't slump on you.
04/15/2009 4:09 PM
Do you see pitting also. Is this made in china and is not a real pyrex. To safe few penny people tried to mimic pyrex with borosilicate glass which is typically window glass.
You can find out very quickly by boiling water in that and observing suface after water evaporated areas withlocation of dried sodium oxide at dry stage.
If pyrex is manufactured in the area where people are melting leaded glass then cross contamination will also do.
In any case I will not use this for cooking
Masyood
Register to Reply 9 comments
Anonymous Poster (2); JohnDG (1); Masyood (1); Mikerho (2); RVZ717 (1); wldnwly (2)
