are two of the many threads. But your answers are already in these.
BTW- in case of questions, try this feature "search?, it will help others in not repeating the same answers.
In case you have some other clarifications on these, post on the same threads and it will retain the linkages rather than starting a new thread and duplicating information.
Re: difference between safety valve and relief valve
04/15/2009 6:49 AM
A safety or relief. valve is a very important protective device. It is designed to avoid accidents by relieving pressure when something goes wrong in the system.
Safety valves and relief valves respond to high pressure in a pipe system. These valves relieve the pressure before it can cause an accident or damage.
Safety valves are used for protection on steam and gas production facilities. Relief valves are generally used on liquid production systems.
Safety valves are commonly called PSV's (Pressure Safety Valves). Relief valves are commonly called PRV's (Pressure Relief Valves).
A safety valve on a gas processing system is usually connected to a flare vent system. The gas escapes to a flare where it is burnt. A safety valve on a steam system will vent to the atmosphere.
Safety valves are set to open (pop) completely at a pre‑set pressure. This pre‑set pressure can be adjusted. The safety valve will stay open until the pressure drops back to the pre‑set lower pressure. The valve should then shut immediately.
The outlet ports on safety valves and relief valves are always larger than the inlet ports. This allows the excess pressure to flow through the valve faster and bring the pressure down to normal quickly.
The safety valve is spring loaded. The spring is adjusted before it is installed. At the pre‑set pressure the spring loaded disc is forced open. It is designed so that the flow pushes the disc fully open. It stays in the fully open position until the pressure falls to below the pre‑set pressure. The spring then snaps the disc to the closed position where it is firmly seated.
The relief valve is normally spring loaded. When the pressure goes above the pre‑set pressure the disc does not go fully open immediately. The amount it opens depends on the amount of excess pressure. The more excess pressure there is, the more the valve opens.
When the pressure falls to the pre‑set pressure, the valve will close gently. There is no loss of liquid because the liquid that escapes is recycled to the suction of the pump or inlet of the vessel it came from, These valves are generally used as relief valves for the thermal expansion of liquids in pipelines.
Look over to the next challenge
i found this in wikipedia (http://en.wikipedia.org/wiki/Safety_valve) u can go there for more detail information
Relief valve
(RV): automatic system that relief by static pressure on a liquid. It
specifically open proportionally with pressure increasing.
Safety valve (SV): automatic
system that relief by static pressure on a gas. It specifically open
almost straight to full lift after a pop sound.
Safety relief valve (SRV): automatic system that relief by static pressure on both gas and liquid.
Pilot-operated safety relief valve (POSRV): automatic system
that relief by remote command from a pilot on which the static pressure
(from equipment to protect) is connected.
Low pressure safety valve (LPSV): automatic system that relief by static pressure on a gas. The pressure is small and near the atmospheric pressure.
Vacuum pressure safety valve (VPSV): automatic system that
relief by static pressure on a gas. The pressure is small, negative and
Low and vacuum pressure safety valve (LVPSV): automatic
system that relief by static pressure on a gas. The pressure is small,
negative or positive and near the atmospheric pressure.
RV, SV and SRV are spring operated (even said spring loaded). LPSV and VPSV are spring operated or weight loaded.
Relief valves are normally used to cater to the possible thermal expansion of liquids due to higher temperature or freezing. Safety valves are for gas, vapours and steam
