Previous in Forum: ASME Code for Multi-Pipe Slugcatcher   Next in Forum: cost of urethane
15 comments
Pressure Relief Valve (PRV) or Pressure Safety Valve (PSV)?
03/18/2009 8:21 AM
Most people say PSV and PRV are same, so why we use different names for them. According to my understanding the PRV (Pressure Relief Valve) is used to regulate the flow of fluid while PSV (Pressure Safety Valve) is used for flow the fluid when the pressure exceeds the design or Max. Available Working Pressure (MAWP) and depressurize the vessel to its low not to regulate it.
Can some body clarify this point?
Mechanical Engineer
Re: Difference b/w PRV & PSV
03/18/2009 8:25 AM
Good post.
PSV can also mean "pressure sustaining valve", and PRV can mean "pressure reducing valve".
Someone, surely, can sort that lot out.....
Good Answers: 103
03/18/2009 8:33 AM
Check previous threads. This has been covered in details already.
Also you may try to google, where it is in detail.
BTW: Both are for pressure the names are clear and none are used to regulate the flow.
For flow (infact as a bye product) you have pressure control valves (PCV)- where the flow is controlled through an orifice to effectively control the down stream pressure.
Since you are a new member (and hopefully will stay back) use the "search this forum" on right side and type in pressure relief you will be taken to all the posts with this subject.
Only for you:
Check this thread
http://cr4.globalspec.com/thread/32517/Pressue-Safety-Valves-vs-Pressure-Relief-Valves
Re: Pressure Relief Valve (PRV) or Pressure Safety Valve (PSV)?
03/19/2009 12:26 AM
PSV and PRV both are related to pressure but there is difference between PSV and PRV.
One is pressure safety valve and one is pressure relief valve.
As the name indicates Pressure safety vavle . it is for safety. The pressure rating of PSV is always higher than PRV. It opens at a larger preeure when PRV fails to operate.
PRV - Pressure relief valve. It relieves the pressure. Pressure rating is always lower than PSV.
A common example of PSV and PRV is pressure cooker , just have a look of it .
Pressure cooker is having both PSV and PRV. The hexagonal shape valve in the cover of pressure cooker is PSV and valve at top which relieves the internal pressure is PRV.
Good Answers: 16
03/19/2009 1:10 AM
The valve on your water heater is both. Excessive pressure or heat will cause it to open.
De gustibus non est dispudandum.
03/19/2009 4:53 AM
The most important words for clarifications already are said by other members of CR4:
- RSV and PRV in principle are the same: both are used to limit the pressure of a hydraulic circuit by opening a bypass for the flow if the pressure reaches the setting limit. The difference in naming is more dependent on the function you are using those devices for. However, a PRV most often is desired to act as a PSV in simple circuit designs.
- Both do not regulate the flow but the pressure only! (of course, the flow to the normal direction becomes affected if rise of pressure getting limited by opening of PSV/PRV, but the valves not taking care about flow rates. The common PRV/PSV therefore are made for a large application range regarding the release flow rate: e.g. for 90 l/min max.
Whether the valves in principle can be used alternatively there are many differences in features possible. A PSV for instance can be of simple and robust design; accuracy and pressure stability (once it opens) can be poor - because protection damage against bursting (damage to humans are in main focus; protection of equipment is a secondary aspect!!) does not require precision but reliability!
For a PRV the requirements for precision in maintaining a constant max. pressure can be essential for an application. In some applications the PRV are used to ensure a constant feeding pressure. The PRV therefore is operated with a (small) opening, releasing a small part of the total pump flow always. For such fuction not only a stable pressure is important but also the PRV must be technically able to deal with the heat generated from permanent release of fluid. Futher more the valves spring characteristic should not lead to oscillations in the hydraulic circuit (resonance problems; especially for applications with high pressure sometimes can drive someone crazy).
Those differences in my opinion are good (and important) arguments to use different names for the valves:
PRV - for valves with "enhenced" features, designed for certain demands on fuctions. This valve type often can take over the function of a PSV in combination.
PSV - simple and robust (and cheap) designs but of highest reliability. These valve usually can't be used successfully as a processing-PRV.
have nice days ...
06/23/2009 3:26 AM
u have explained it nicely but just for my clarification what i have understood is prv acts as both psv & prv but psv operates by brusting or opening & never seats back & equipment protection is damaged.so it means psv has to be replaced everytime it operates.......please correct me if i am, wrong
03/19/2009 9:06 AM
Also depends on the application of these valves.........
e.g. On a diesel engine lubrication system you will have a pressure relief valve......this prevents over pressurisation in the circuit and controls circuit pressure............this maybe set at say 55 psi. Also in the circuit you can have a safety valve that is set at at 5 psi above relief valve pressure.
This is Incorporated because under certain conditions the relief valve may not be able to control the rapid oil pressure rise........the safety valve then operates to prevent excessive pressure build up that could damage filters.oil coolers, etc.
An example of where you may not have a relief valve and only a safety valve, is a boiler..............once excess pressure occurs in the boiler a pilot operated full-bore safety valve lifts and relieves excess pressure to atmosphere via a waste steam pipe.............and this occurs with a deafening roar...........once the pressure drops to its predetermined operating pressure the valve slams shut............without leaking..........we hope
03/21/2009 7:58 PM
Pressure relief valves are commonly used to protect a fluid powered, maybe some air powered (if necessary), and or gas powered(if necessary) systems or any system that will protect it from overpressure and just stalling a process.
In hydraulics(hydrostatic application), a pressure control valve termed as pressure relief valve protects the system pressure that may be caused by too much resistance on pressurized fluid or in some cases against pressure build-up due to fluid thermal expansion. As a pressure control valve, they only control the pressure and dont be confused as to why some hydraulic actuators move faster when you increase the relief valve setting (its a different case). They dont control flow.
Relief valves are mainly normally closed valves and any action that may cause this valve to open at higher pressures are considered power losses converted to heat(termed as Pressure drop=difference in pressure across the valve ports=my name).
Pressure safety valve is quite a very broad term, and a pressure relief valve can be considered a pressure safety valve since it can be adjusted to protect any system from getting damaged due to overpressure but would just stall the machine and not tripping any prime mover. A pressure switch, pressure transducer and pressure gauge with electrical connections can be used to protect/monitor or dictate pressured systems but IMO I cant consider them as valves.
Good Answers: 12
Re: Pressure reducing Valve (PRV) is different than pressure relief valve
04/08/2009 2:58 PM
Practically there is an essential different between both valves , they are not similar but completely different even in design or in function .
First let us identify what means by P.R.V ? It's a pressure reducing valve ,this definition is better and more practically than pressure regulating valve. Why?.
Because the main function for P.R.V is to reduce pressure for main distribution line with high pressure to individual line with lower pressure .
why we need to reduce pressure??
Because main line ( steam for example ) may be under boiler pressure assume 10 bars (for example ) while we have a certain machine with maximum working pressure 4 bar.
In such case we need to reduce pressure from 10 to 4 bars to be suitable for usage with that machine. how we reduce pressure from 10 to 4 bars?
The P.R.V ( pressure reducing valve) is the main device which done that reduction.
for different machines working under different pressures , we need separate P.R.V
for each machine to reduce pressure from 10 bar ( in our example)to the suitable working pressure for each one separately.
What if the P.R.v failed to reduce pressure???? .
simply our machine which is working with maximum pressure 4 bar will suddenly face 10 bar pressure,it will be seriously damaged, it may be exploded.
how can we save that machine from pressure rising up for more than maximum working pressure?
now we are arrived for safety valve or it may named pressure relief valve
The main task of safety valve is to open in case of pressure rising up for higher than maximum allowable pressure and exhaust or relive excess pressure to atmosphere, it will continue open until pressure return back for maximum allowable pressure . 4 bar in our example.
Briefly safety or pressure relive valve is a safety device,it prevents pressure rising up more than maximum working pressure, this in case of P.R.V failure.
practically safety valve is adjusted to open at a slightly higher pressure than maximum allowable pressure ( it called setting pressure of safety valve) in our example it may adjusting to 4.2 bar.
finally P.R.V must be equipped with Safety valve to save system in case of P.R.V failure
safety valve is fitted after pressure reducing valve in direction of low pressure zone.
while safety valve may be installed separately, like in pressure tanks, hydraulic pumps, water heaters, boilers -----etc. in all these cases it opens to save system from excessive pressure . it,s not a pressure regulating valve
Finaly PRV Is a pessure reducing valve ,it's not a pressure relive valve .
I hope it may be enough for you.
don't tell me who are you , what do you know is enough.
08/05/2009 2:52 AM
Safety Valve for Gas
Relief Valve for Liqued
Safety Relief Valve for both Gas & Liqued
04/16/2010 4:31 AM
hi,My understand :PRV(pressure relief valve) is used for gas or liquid or both two phase fluid. PSV(pressure safety valve) is used for gas only.therefore PSV is one type of PRV.
09/29/2010 11:11 AM
In systems containing liquid you can have both valves. e.g. in lubrication systems on some diesel engines you have a relief valve set at a specified pressure, as well as a safety valve that is set at, say 5 psi above the relief valve pressure.
01/13/2025 7:10 AM
<...PSV...> can also mean "pressure sustaining valve" - hence the overwhelming need to define TLAs before using them, especially in this forum.
09/28/2010 9:19 AM
In ammonia line what is the difference between PRV and TRV
01/13/2025 7:08 AM
Register to Reply 15 comments
Albert Caspers (GER) (1); Anonymous Poster (5); Dilip Kumar Singh (1); khairy Aish (1); MOBI (2); Pressure Drop (1); PWSlack (2); sb (1); Tippycanoe (1)
