Previous in Forum: Fixing a Noisy Transformer   Next in Forum: whose accuracy is more measuring or protection CT
Good Answers: 244
UPS Design Question
04/17/2009 12:17 PM
I am designing a UPS system of output rating 40KVA. Based on the UPS capacity, I am selecting Inverter (40KVA), Bypass Transformer (40KVA), Static Switch (40KVA) and Maintenance Bypass Switch (40KVA).
Are these ratings correct?
We have another existing 30KVA UPS system and it has Inverter (30KVA), Bypass Transformer (37.5KVA), Static Switch (30KVA) and Maintenance Bypass Switch (45KVA).
Is there any specific technical reason why the KVA are different in the existing UPS?
Thanks in advance.
-MS
Re: UPS Design Question
04/18/2009 3:47 AM
Dear,
Not exactly true for designing a system with all the equipments of same rating.
WE must consider the performance of each equipment individually to take up the full load of 40kva continuous without de rating. at max. ambient temp. / humidity / geographical height / nature of load .... inductive, heating, max. 3rd harmonics , continuous , etc...
Further, in cases of short circuits or over voltages, other equipments should not blow off along with the faulty one.
Isolator carries a high reactive currents , i.e. arcing currents. So, they will be derated more.
So, if you design accordingly,
When Inverter is of 40 kva, Transformer feeding to it will be 20% more. i.e. 48 kva
Making & breaking current duty selection, by pass Isolator shall be 50% more i.e. 60 kva
Exploring the Science of Electricity
Good Answers: 19
04/19/2009 12:30 AM
Normally we design as follows:
for 40 kVA load ,taking inverter efficiency to 90%, we select inverter of 40/.9=44.44, rounded off to 45 kVA, since the market does not provide 45 kVA,we go in for 50 kVA rating.
The neutral to be rated for double the phase current,therefore we select the switchgear 4 pole,rated for 2 times the phase current,inthis case 50 *1.4*2=140 amps,standard rating of switchgear available is 160Amps,so select 160 Amps.
Alternatively you can select 100 Amps 3 pole switchgear and 160 Amps nutral link.
Bypass arrangement can be rated for 40 kVA.
Ramesh,Freelance Electrical/automation Consultant
Register to Reply 2 comments
