Previous in Forum: Position Transmitter   Next in Forum: Centrifugal Compressor
Level Calibration
04/18/2009 10:20 PM
hi everyone ,
what is the standard proceedure to calibrate capacitance type of leveltrol in workshop ?
we are calibrating with liquid (light naptha) but that doesn't work with water
I want to know the correct way of calibration
regards
Adil
Re: Level Calibration
04/19/2009 10:24 PM
What does your supplier suggest? Do you have one?
Where is the spec sheet for your device?
If you don't have a clue what I'm talking about, why don't you just admit it up front?
04/20/2009 3:55 AM
Capacitance level gauges can only be used in connection with the liquid they are inteded for. Using them on other liquids, with different dielectric properties, will give errors in the reading with unexpected results, including vessel overfill.
Generally, capacitance should be seen as a last-resort technique for measuring level, as the slightest change in liquid properties can have a vast impace on the operation of the device.
It might be easier to go radar instead. It will certainly be less hassle.
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
04/20/2009 6:21 AM
Hello
Which make is this. Do you have a manual , i could get you one if you provide the model no.
Different models have different cal procedures.
Also why use naphtha when you want to work with water , use water to calibrate as well.
Regards
Naveen
lyn (1); naveen_menon (1); PWSlack (1)
