Previous in Forum: boiler drum   Next in Forum: post weld heat treated
End Connection of Reducing Tee (Options)
04/20/2009 6:18 AM
Whether end connections of Reducing Tee (50x50x40) are
-All ends flanged or
- Two ends BW & one as SW.
Pl. provide a valid reason for any option.
Class is 150#, MOC – SS A403WP304/304L, 10S, Safety Shower &
drinking water.
Thanx
Be simple and specific for a great success in Life
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: End connection of Reducing Tee(options)
04/20/2009 6:21 AM
Well, I'd look up the piping standard for that service. I can sell you one if you ain't got none. <Splutter>
Essex jobs for Essex yobs! <Burp>.
04/20/2009 6:43 AM
Does the pipe piece have to disassembled at any time? Such a criterion would preclude the use of welding.
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Piping Design Engineering - New Member
Re: End Connection of Reducing Tee (Options)
04/21/2009 4:22 AM
You can go for BW/SW as thenmediyum is not hazardous and moreoever the safety shower and the drinking water is not going to be used frquently in site unless & until there is a maintenance. So I prefer using the aobe connection as the best suited. Also the cost wise flanges would be expensive for this safety shower use.
Register to Reply 3 comments
Kumaran (1); PWSlack (1); Stinky Pete (1)
You might be interested in: Hose Fittings, Gas Springs, Pressure Regulators
