Previous in Forum: Dish end fabricartion   Next in Forum: Energy cost reduction for HVAC on a production floor
Particle size reduction
04/22/2009 12:45 PM
Anyone knows a company able to reduce the size of mineral powder from 20-40µm to less than 100nm please? Thanks.
I'd be very happy to learn who they are !! Location: pref. Europe
Re: Particle size reduction
04/22/2009 7:28 PM
It would help very much if you inform about the mineral powder you're talking about, expected composition, hardness, and volume you'd expect to work with over time. You'd be surprised with the several different ways to break particles in a manual or semi-automatic way (I used to do a lot of it during my days in a welding lab at university). But it may not be feasable depending on your process parameters.
Humm... suspicious you are...
04/23/2009 4:02 AM
It's titaniumdioxide silverchloride complex.
04/23/2009 4:20 AM
Contact M/s nybolt sweden based filter cloth manafacturer i had used their filter for 10micron size filtering.you need sifter to do the job i was using M/s Buhler Bros equipment Number of filter manafacturers are there to serch on the internet
crm
04/23/2009 4:51 AM
Hi ghost,
please try www.wlw.de this is a large supplier directory, and you can also use the english version. I tried the german search and got a list with 70 potential suppliers. Hope this this will be of service to you!
regards nudnik
04/23/2009 10:57 AM
Try these guys. They are located in France.
http://www.sd-tech.com/
04/23/2009 12:25 PM
I could give it a whirl.
Our cryogenic ball-mill should mill it down to that size. The time in mill (#hours) required to reduce it from 40u to <100nm is to be determined for titanium dioxide silver chloride. You could do a characterization run where we pull a sample out say every hour or 3-5-8 hours, and put in an in-house scanning electron microscope that can confirm post-milling particle size. A run like this would be about 1Kg (2lbs) of powder. Then we could proceed from there.
How much material are you trying to process?
please feel free to contact me
Steven Schroeder
California Nanotechnologies
steven.schroeder@calnanocorp.com
ph:USA (714)483-3973
Register to Reply 6 comments
bhrescobar (1); Ghost (1); murali (1); nudnik (1); Rheolog (1); Schroeder (1)
