Previous in Forum: RTDs and Incorrect Temperatures   Next in Forum: pH Controller
Sun Shade Protection
04/28/2009 1:30 PM
Hello Frnds
Ther are these Client standards mentioning the requirement for Sunshade Protection for Local Instruments (Tranmitters)
If the instrument is rated is rated for IP 66 , Nema 4X, Can i Bypass these shelters??
Regards
Jose John
Re: Sun Shade Protection
04/28/2009 2:10 PM
No.
The IP and NEMA ratings don't spec or protect against the radiant heat from the sun.
You don't say where this project is located. I work in the desert where temperatures can get to 125 Deg F (in the shade!). If the cabinet holding my PLCs and instrumentation aren't shaded, I have seen it reach 160 Deg F inside the enclosure. Not good, since the PLCs and radio modems die at 140 Deg F.
A sunshade is a lot cheaper than $10K-$20K of fried electronics.
04/28/2009 3:23 PM
No, that's like standing outside in the hot sun with a raincoat on. No protection.
Bear in mind that a sun shade doesn't necessary mean an enclosed shelter surrounding the enclosure being protected, it can consist of as little as a sheet of steel supported on an angle above the enclosure to block the sun (depending on the situation).
04/28/2009 7:20 PM
NO!
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
04/29/2009 1:09 AM
when you say local instruments does that include only transmitters/ guages etc or does it also include PLC's etc.
For guages and others in same category no Sunshade required.
For plc's - alwyas better to have enclosures which are temperature controlled.
For transmitters it is better to have sunshades mate. Ussually good tx like Rosemount provide good lperformance even in ambient from -40 to 85 dc.
South Africa - Member -
Good Answers: 12
04/29/2009 1:32 AM
Hi all,
Sunshade is ok. The real problem is UV (Ultra violet) protection for the casing. The other problem would be solar radiation (temperature effect).
The IP/NEMA rating is only for ingress protection - not UV or temperature.
If the ambient temperature is very hot - you will have to use either sun shade or some sort of enclosure with purging for cooling.
Either way - if their specification calls for this, you cannot bypass it on IP rating or NEMA alone.
Regards,
Craig
06/11/2009 7:56 AM
There instrument sunshades UV resistant and fire retardant,made for yr. requirement.
I know the company BULK srl in Italy www.bulksrl.it or there are also some in Germany.
Hope this could help you
Mauro
08/03/2009 4:28 PM
Sun shades are often used to protect an instruments LCD display, which is vulnerable to damage from long term direct exposure to UV rays, even if temp considerations are not a problem.
Regards,
Bill
Register to Reply 7 comments
Anonymous Poster (2); craigza (1); jack of all trades (1); Kilowatt0 (1); lyn (1); naveen_menon (1)
You might be interested in: NEMA and IP Enclosures, AC Power Cords, IP Cores
