Previous in Forum: Sun Shade Protection   Next in Forum: Loop
pH Controller
04/29/2009 4:04 AM
I'm planning to set-up an automated water acidification system. The desired pH range is 5 -6. The raw water pH is 7.8. Is it possible to automate the in-line acid feeding to adjust the pH? I will be using GF signet pH controller w/ sensor after the static mixer with injection quill where sufuric acid will be injected and mixed w/ the stream. I would like to control the acid feeding within the specified range.
Re: pH Controller
04/29/2009 4:09 AM
Some means of modulating either the acidity of the injectant or its flowrate will be needed. The modulation signal is an output from 3-term PID control - does the GF Signet unit have this functionality? If not then a separate 3-term controller will be needed.
Why does the pH need to be adjusted to 5-6?
Re: pH Controller
04/29/2009 4:25 AM
I would like to convert the alkalinity to carbon dioxide and remove it by degassification. pH lower than 5 would mean insufficient alkalinity conversion while pH higher than six would cause high sulfates concentration in the product water which is undesirable. the gf signet pH controller only has 4-20 mA output and my metering pump has 4-20mA input.
Re: pH Controller
04/29/2009 4:36 AM
OK, then a 3-term controller would be needed in addition to the kit described. How about Eurotherm <usual disclaimer>?
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: pH Controller
04/29/2009 4:51 AM
how about something like a lake wood controller kit for this application
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
Re: pH Controller
04/29/2009 4:10 PM
hi joozmax6 you require a PID controller you can select SIPART DR controller as per your requirement , http://pia.khe.siemens.com/index-process_instrumentation-process_controllers-2140.htm
find2am (1); joozmax6 (1); naveen_menon (1); PWSlack (2)
You might be interested in: pH Electrodes, pH Transmitters, Lead Acid Batteries
