Previous in Forum: Beam Alignment   Next in Forum: Impact Resistance for LEXAN or Makrolon
Engineering Fields - Mechanical Engineering - I am here to help!!
High-Strength Steel for Welding
04/29/2009 11:33 AM
Is there any alloy steel & structural steel having yield strength above 80 kgf/sq mm & still weldable?
Good Answers: 74
Re: High-Strength Steel for Welding
04/29/2009 9:38 PM
No!
Bruce
04/30/2009 7:04 PM
Several do. SAE 43XX series have good weldability and high strengh, and are the first choice as I understood from your question. SAE1045 steel have reasonable weldability and do well with proper treatment. More money involved? Martensitic stainless steel can do. The problem is not the steel itself, but the possibility or not of getting the proper post weld treatment, and the welding process itself. Whats the problem specifically? What are the contour conditions? Maybe we can help more...
Humm... suspicious you are...
Register to Reply 2 comments
